I have been searching for permissions issues for about 2 hours now. Everything I find tells me how to edit permissions on Datasets. All TrueNas documentation seems to indicate the same thing... I have been using these pools since Freenas 9, back when you could set permissions on root datasets. As I upgraded, I never added child datasets, and keep permissions wide open as this is a simple home server, and security is not a concern. Now in Truenas 12, root can no longer authenticate through SMB. I created a user to authenticate through SMB, and I edited my SMB share's permissions to allow everyone access (open profile). I cannot edit dataset ACLs because there are no child datasets in the pools, and the option to edit root dataset permissions was lost in FreeNas 11. I have full read access, but no write access. I created a test dataset on one of my pools, and I was able to read and write freely to it.
I have 2 questions.
1. In order to have full access to my data (read/write/create new folders), must I put my data into child datasets?
2. if yes, Is there a better way to get my 180TB of data into a dataset? Copying takes a long time, even within the same pool. I assume this is because permissions must be assigned to each file?
I'm almost certain that my hardware is irrelivent, so I did not specify. I will check back tomorrow to see if anyone wants anymore information. Thank you for your time.
-Paul
Version:
TrueNAS-12.0-U1
			I have 2 questions.
-Paul
Version:
TrueNAS-12.0-U1
