SNMP not working
raymonvdm
I mn trying to get SNMP working on a FreeNAS-8.0-RELEASE-i386 build but it is failing.
The boxes have a static ip but when i check netstat -nl snmp is not listed
freenas# netstat -nl
Active Internet connections
Proto Recv-Q Send-Q  Local Address          Foreign Address       (state)
tcp4       0      0 192.168.110.190.80     192.168.110.50.54399   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54397   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54396   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54395   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54394   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54393   TIME_WAIT
tcp4       0      0 192.168.110.190.80     192.168.110.50.54392   TIME_WAIT
tcp4       0      0 192.168.110.190.22     192.168.110.50.45419   ESTABLISHED
tcp4       0      0 192.168.110.190.2049   192.168.110.195.916    ESTABLISHED
udp4       0      0 127.0.0.1.53405        127.0.0.1.162
udp4       0      0 127.0.0.1.123          *.*
udp6       0      0 ::1.123                                       *.*
udp6       0      0 fe80:2::1.123                                 *.*
udp4       0      0 192.168.110.190.123    *.*
udp4       0      0 192.168.110.255.138    *.*
udp4       0      0 192.168.110.190.138    *.*
udp4       0      0 192.168.110.255.137    *.*
udp4       0      0 192.168.110.190.137    *.*
Active UNIX domain sockets
Address  Type   Recv-Q Send-Q    Inode     Conn     Refs  Nextref Addr
cd928560 stream      0      0 cb7feb84        0        0        0 /var/run/snmpd.sock
cd9276b8 stream      0      0 cdbd1860        0        0        0 /tmp/django.sock
cd927810 stream      0      0 cda48a78        0        0        0 /var/run/rpcbind.sock
cd927d70 stream      0      0 cda40a78        0        0        0 /var/run/devd.pipe
cd92735c dgram       0      0        0 cd927968        0 cd927204
cd927b6c dgram       0      0        0 cd927a14        0        0
cd927204 dgram       0      0        0 cd927968        0 cd927ec8
cd927ec8 dgram       0      0        0 cd927968        0 cd928000
cd928000 dgram       0      0        0 cd927968        0 cd927408
cd927408 dgram       0      0        0 cd927968        0 cd927c18
cd927c18 dgram       0      0        0 cd927968        0 cd92760c
cd92760c dgram       0      0        0 cd927968        0 cd927764
cd927764 dgram       0      0        0 cd927968        0 cd9278bc
cd9278bc dgram       0      0        0 cd927968        0        0
cd927968 dgram       0      0 cda50000        0 cd92735c        0 /var/run/logpriv
cd927a14 dgram       0      0 cda5010c        0 cd927b6c        0 /var/run/log
freenas#
I already modified the host file
::1                     localhost localhost.my.domain freenas freenas.local
127.0.0.1               localhost localhost.my.domain freenas freenas.local
192.168.110.190         freenas.domainname.org
And also tried to edit /etc/snmpd.conf
# open standard SNMP ports
begemotSnmpdPortStatus.[freenas.domainname.org].161 = 1
begemotSnmpdPortStatus.127.0.0.1.161 = 1
#begemotSnmpdPortStatus.192.168.110.190.161 = 1
But stil no luck. I would like to use Cacti to make graphs of the interfaces en disks. I already have a dedicated cacti box to use for al my other machines so cacti is not the problem.
joeschmuck
Old Man
Yes, download the latest nightly build (more recent than Beta-4) and create the CD via the iso file. Boot your FreeNAS from the CD and do the install.
