Hi all,
I am attempting to find the cause of my miscalculation when attempting to retrieve the zpool total size, available size, and used size of one of my pools via SNMP. This is only affecting one of my pools.
I am retrieving the values when running:
The offending pool values
Pool name:
Allocation Units:
Total size:
I am calculating the total bytes by multiplying the zpoolAllocationUnits by zpoolSize.
Then taking that value and dividing by 1099511627776 to get total TiB:
90.75 is not correct. It should be 67.
Here is an example for available space (to have another data point):
(zpoolAllocationUnits * zpoolAvailable) / 1099511627776 = x
Output of "zfs get" for sanity's sake:
A correct pool value
Pool name:
Allocation Units:
Total size:
This comes out to 3.625TiB. This is correct!
Something about the oddball zpoolAllocationUnits is messing up the calculation.
System information:
Thanks!
snmpwalk -v 2c -c [community] [IP of NAS] 1.3.6.1.4.1.50536.1.1The offending pool values
Pool name:
FREENAS-MIB::zpoolDescr.3 = STRING: pool4Allocation Units:
FREENAS-MIB::zpoolAllocationUnits.3 = INTEGER: 65536 BytesTotal size:
FREENAS-MIB::zpoolSize.3 = INTEGER: 1522532352I am calculating the total bytes by multiplying the zpoolAllocationUnits by zpoolSize.
65536*1522532352 = 99780680220672Then taking that value and dividing by 1099511627776 to get total TiB:
99780680220672/1099511627776 = 90.7590.75 is not correct. It should be 67.
(65536*1211604351)/1099511627776 =72.21Output of "zfs get" for sanity's sake:
root@nas1:~ # zfs get all pool4 NAME PROPERTY VALUE SOURCE pool4 type filesystem - pool4 creation Fri May 15 17:10 2020 - pool4 used 14.1T - pool4 available 52.9T -
Pool name:
FREENAS-MIB::zpoolDescr.2 = STRING: pool3Allocation Units:
FREENAS-MIB::zpoolAllocationUnits.2 = INTEGER: 4096 BytesTotal size:
FREENAS-MIB::zpoolSize.2 = INTEGER: 973078528This comes out to 3.625TiB. This is correct!
System information:
- Supermicro X9DRD-7LN4F
- Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
- 64GB RAM
- Drive info:
- "pool4"
- 10x10TB
- WD Reds
- RaidZ2
- "pool3"
- 4x2TB
- WD Gold
- Raid10
- 2x300GB SSD ZIL
- "volume1"
- 4x1TB
- Samsung EVO SSD
- Raid 10
- "volume2"
- 4x500GB
- Samsung EVO SSD
- Raid 10
- "pool4"
- Controllers: Onboard and 2x LSI 9211-8I
- NIC: IBM Mellanox ConnectX-2 EN Dual SFP+ 10GigE PCI-e 2.0 x8 81Y1541
Thanks!
