snapshot data from elasticsearch to nfs key encrypted dataset
Momtez
I've been stuck for several days on snapshotting data from Elasticsearch to an encrypted dataset with a key. I need your help, please.
I've mounted an NFS partition on Elasticsearch pointing to an encrypted dataset with a key on TrueNAS. When I try to initiate a data snapshot from Elasticsearch to TrueNAS, I receive the following error:
/var/nfs/elasticsearch': Input/output error
cannot read directory '/var/nfs/elasticsearch': Input/output error
However, the dataset is currently unlocked.
I'm using the following command to mount the NFS partition:
mount -t nfs truenas IP:/mnt/VDEV/elasticsearch /var/nfs/elasticsearch (This command succeeds)
I do have the key for the encrypted dataset.
For reference, I can successfully take a snapshot on a dataset that is not encrypted on TrueNAS.
  1. Do I need to adapt the mount command by adding the key somewhere?
  2. Generally, how do I lock/unlock the dataset?
Any guidance would be greatly appreciated.
Thank you.
