SMB Tuning for 10MB Files - OSX - 25GbE/40GbE
benjamin604
I've got a test server up and running, Hardware is:
Hardware
HP Z840
Dual Xeon E5-2687W v3 @ 3.10GHz
128GB Ram
Mellanox Connect-x 5 Dual 25Gb
8 x 2TB Samsung 860 SSDs
1 x 1TB Samsung 860 SSD for TrueNAS core
TrueNAS-12.0-U6
Storage Pool
Single Raidz vdev with 11.85TiB usable
Single SMB Dataset with 3.51GiB used
no compression
no sync
no atime
record size 128KiB
Tuneables
SMB Config
root@truenas[/mnt/RaidZSSD/SMBDataset]# testparm -a
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
disable spoolss = Yes
dns proxy = No
enable web service discovery = Yes
kernel change notify = No
load printers = No
logging = file
map to guest = Bad User
max log size = 5120
registry shares = Yes
server role = standalone server
server string = TrueNAS Server
unix extensions = No
fruit:nfs_aces = No
idmap config * : backend = tdb
directory name cache size = 0
dos filemode = Yes
[smb]
ea support = No
guest ok = Yes
level2 oplocks = No
oplocks = No
path = /mnt/RaidZSSD/SMBDataset
read only = No
strict sync = No
vfs objects = fruit streams_xattr shadow_copy_zfs noacl aio_fbsd
fruit:metadata = stream
fruit:resource = stream
nfs4:chown = true
Client Machine
Mac Mini 2018
6 Core i7 3.2GHz
32Gb RAM
500Gb NVMe
Atto Thunderlink NS 3252 connected with TB3
Disabled Network DSStore
Network
Directly connected at 25Gb with Mellanox Optics, MTU 9000
iperf looks pretty much as expected:
The Issue!
We're trying to move Arri camera media around for either ingest or backup to LTO. I've been testing with test media for the time being, just simple copies to and from the storage.
The performance of the disk looks fine. Here's IOZone for 10MB filesize (the size of Arri HDE files)
root@truenas[/mnt/RaidZSSD/SMBDataset/linux]# iozone -a -s 10240
        Iozone: Performance Test of File I/O
                Version $Revision: 3.487 $
                Compiled for 64 bit mode.
                Build: freebsd
        Run began: Wed Oct 27 14:23:45 2021
        Auto Mode
        File size set to 10240 kB
        Command line used: iozone -a -s 10240
        Output is in kBytes/sec
        Time Resolution = 0.000001 seconds.
        Processor cache size set to 1024 kBytes.
        Processor cache line size set to 32 bytes.
        File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
           10240       4   799557   850289  2535279  2535279  2038543   963325  2104777    973191   2042226  1017697  1020526  2378191  2374772
           10240       8  1536836  2071980  4523015  4533039  3707414  1837748  3647900   1904404   3660960  1980725  1985670  3929591  3969175
           10240      16  2345976  3366013  6890905  6928701  5885285  3114370  6023116   3300062   5933254  3392869  3424793  5259054  5308454
           10240      32  3291463  5592546 10209568 10280438  9126954  5278443  9226952   5556371   9173741  5537744  5583821  6867765  6961268
           10240      64  4092469  8569700 12980415 12960830 11917865  8108598 11934423   8598867  11961012  8441688  8498481  7907070  8094844
           10240     128  9094101 11021764 13159384 13314401 12737884 10634250 12533442  11179553  12768178 10926429 10915322  7545878  7792305
           10240     256  8597146 10352298 12160825 12160825 11951028 10231458 11937741  10322441  12017909 10387349 10397408  6210364  6547400
           10240     512  8448330 10302632 12817715 12879213 12688962 10248547 12640414  10282899  12610723 10270604 10260789  5922617  6732128
           10240    1024  8715780 10568830 13248688 13232361 13147299 10514495 13059352  10545475  13297912 10558437 10566230  6059657  6854612
           10240    2048  8706946 10732573 13027662 13011875 12945204 10634250 12879213  10743311  13043488 10743311 10767552  5403286  6719489
           10240    4096  7809376 10654824 13085407 13045661 13045661 10638329 12918138  10734715  13001235 10668056 10711290  4162392  6687628
           10240    8192  5769116 10266427 12409588 12450057 12778810 10202411 12486251  10504976  12679779 10450659 10381195  2439662  5013234
iozone test complete.
Moving larger RED files (approximately 5GB in size) I get 1.8/1.9GB/s
which for such a small array of disks is pretty good, read is similar.
For the 10MB Arri files, however:
200MB/s. Rubbish.
Can anyone point me in a direction? More
With smaller files, you'll be hammering metadata more, so I would suggest adding a metadata VDEV on some mirrored SSDs might cover it.
If the NFS speed is acceptable (hence not a pool problem as such), you might check out the Linus Tech Tips video where they tune SMB for media files and see if messing with that can help.
benjamin604
That's what inspired this build, we're GPFS on our main cluster, but saw that and thought we'd give SMB another go.
So, I've basically copied their config, slightly adjusted for our SSD rather than NVMe disks.
I'll give the metadata VDEV a go.
I note that in the Linus video they also set the dataset(s) to use metadata only ARC/L2ARC, so maybe there's something to that (I would guess it should already be in ARC though since you have plenty of RAM, so I don't see how it can help)
Maybe it's worth thinking about more RAM as the speed of the other components you're talking about here shouldn't be slowing things down, so maybe it's a lack of RAM.
