Hi there,
So I'm having problems reaching transfer speeds of above ~10MB/s (both ways). I've tried transferring via SFTP (Which gives 6MB/s Read) and CIFS (Which gives 10MB/s Read).
To try and isolate the issue, I've done an iperf test as well as an iozone benchmark. Probably not the best tools for the situation but its a start. :) [Would greatly appreciate other recommendations for testing]
iperf yielded similar results @ around 10MB/s
and IOzone gave me fair results. (at around 90% miss percentage during random read) (So I can assume its not the problem of my array)
Not the best way to test but, it's all I've got. :(
SAMBA isn't this reliant on CPU performance, is it? Does one only get 10MB/s with an Intel C2550 Avoton processor?
Run began: Wed Sep 28 23:18:25 2016 Auto Mode File size set to 33554432 KB Record Size 4096 KB Command line used: iozone -a -s 32g -r 4096 Output is in Kbytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 Kbytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride KB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 33554432 4096 1599129 1414199 1472084 1470345 501216 1398494 511318 1917500 508462 1448576 1389642 935656 934432
