smb.syncronize_group_mappings fails in v21.08
sgt_jamez
Is anyone else getting this error?
How do I correct it?
anodos
Sambassador
You should be able to see the exact error message in the GUI for jobs or by running command midclt call core.get_jobs '[["method", "=", "smb.synchronize_group_mappings"]]' | jq
sgt_jamez
Not sure how to interpret this, but here is the result of the command:
krustynas# midclt call core.get_jobs '[["method", "=", "smb.synchronize_group_mappings"]]' | jq [ { "id": 22, "method": "smb.synchronize_group_mappings", "arguments": [], "description": null, "abortable": false, "logs_path": null, "logs_excerpt": null, "progress": { "percent": null, "description": null, "extra": null }, "result": null, "error": "'sid'", "exception": "Traceback (most recent call last):\n File \"/usr/lib/python3/dist-packages/middlewared/job.py\", line 382, in run\n await self.future\n File \"/usr/lib/python3/dist-packages/middlewared/job.py\", line 418, in __run_body\n rv = await self.method(*([self] + args))\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py\", line 410, in synchronize_group_mappings\n await self.sync_foreign_groups()\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py\", line 129, in sync_foreign_groups\n domain_sid = domain_info['sid']\nKeyError: 'sid'\n", "exc_info": { "type": "KeyError", "extra": null }, "state": "FAILED", "time_started": { "$date": 1630770140030 }, "time_finished": { "$date": 1630770152936 } } ]
anodos
Sambassador
Hmm... I'll have to look at that on Monday, but try the following:
rm /var/db/system/samba4/group_mapping.tdb
midclt call smb.synchronize_group_mappings -job
Then see if it clears up.
sgt_jamez
I don't think it did.
krustynas# midclt call smb.synchronize_group_mappings -job Status: (none) Total Progress: [________________________________________] 0.00% 'sid' Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 382, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 418, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py", line 410, in synchronize_group_mappings await self.sync_foreign_groups() File "/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py", line 129, in sync_foreign_groups domain_sid = domain_info['sid'] KeyError: 'sid'
sgt_jamez
Solved! The nightly fixed my ACL issues as well.
