- Apr 16, 2020
I like living dangerously.
All VM's moved to local storage on the hosts
Backups (both) completed sucessfully
So I pulled the trigger
The upgrade seemed to go well - so its time to test.
Pools & Datasets present - tick
SMB Shares present & correct - tick
Encrypted Dataset, unencrypted - tick
iSCSI Shares stopped
NFS Shares stopped
Scrub Tasks - Correct
Snapshot Tasks - Correct
Replication Tasks - Correct
Cloud Sync Tasks - Correct & Run
Rsync Tasks - there aren't any - Correct
S.M.A.R.T. Tests - Correct
Network - Both interfaces present & correct
Global Config - Correct
Static Routes - Correct
Active Directory - Healthy
Virtualisation - 2 test guests present but won't run due to incorrect NIC. Assigned a NIC and to my suprise they boot
Not seeing anything else wrong - Even UPS says its running - although I am expecting issues here - there are error messages in syslog
Reporting - CPU Temps look interesting and bear no resemblence to the dashboard widgit (which seems correct of the two as it matches what the Core system was saying.) Scale temp reporting is saying Min -20, Mean 9.46, Max 12.13 - which is rubbish. Not important
But NFS & iSCSI not starting
iSCSI - Nothing overtly wrong - just won't start. Fills the console with a load of what don't look like error messages - just fails to start after a few seconds
NFS - Fails to start immediately and again I don't see anything wrong.
I can rebuild the iSCSI setup from scratch (which might fix the issue) - as there is nothing in any of the zvols
But the NFS is a bit worrying as its kinda important - but again its just shares - so could be rebuilt. However I think its a bit more serious. I have a tset scale box and the only difference between the two on the NFS service config is that on the side graded NAS NFSv3 ownership model for NFSv4 is grayed out
Anyone know where I should look for clues?
NFS Shares stopped
