SMB shares not showing up on Android
Prophet4NO1
My SMB shares no longer are showing up in Android devices. They show fine on Windows and Linux though. Not sure what is going on.
OS - TrueNAS 12.0
I tried turning on SMB1 support. That used to fix the issue. Not this time. Any thoughts on other causes? I can see other computers on my network using SMB, just not my TrueNAS box. I have changed nothing as far as permissions or anything like that. Guest access was turned on to see if that would solve the problem, nope.
Prophet4NO1
Enable netbios nameserver under Network->Global Configuration.
That fixed it. Thanks. Does it sometimes turn off after updates? It had been trouble free for a few years up to this point aside from having to turn SMB1 support after some updates. But that was the only issue in the past.
