SMB Shares Issue
thebrochan
I have my server setup with two drives (mirrored)
I have the shares setup on my windows desktop and then from there I access my files and move them around and delete. All of this worked when I was running FreeNAS 11.3.
I did a fresh install of TrueNAS last night and added my existing pools. I went through the documentation and followed the steps to enable the SMB shares and add it.
When trying to access the shares it works great, I can browse the directory and see all my files. When I go to delete, add or move files I get an error that says
"you require permission from unix user\root to make changes to this file"
I have gone through the forums and done google searches and nothing seems to be working. I either can't edit the files or I get login errors saying incorrect user name/password.
Please see attached for some screenshots of how things were setup. I have tried added new users to different groups, and still no luck...
I got to a point where I could login then, it asks for another login where it denies me.
thebrochan
Gave up trying to set permissions. I copied all the data to another drive, deleted the entire pool/dataset. Recreated it with proper datasets, set permissions, data is copying over now and everything is working.
TrueNAS no longer allows root access to SMB shares
thebrochan
Yep I did come across this early on in my search but I thought there was a way to do it via CLI, just to allow me to move data into the new dataset and then delete, but no luck. The good thing is I was able to get everything setup correctly. Will unfortunately need to do the same on my Plex server eventually.
