SMB shares - different parameters though GUI looks identical?
Patrick M. Hausen
Hi all,
I just wanted to help in that thread stating problems with Mac clients after the update to TN 12 when I noticed something really odd:
root@freenas[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
    aio max threads = 2
    bind interfaces only = Yes
    disable spoolss = Yes
    dns proxy = No
    enable web service discovery = Yes
    kernel change notify = No
    load printers = No
    logging = file
    map to guest = Bad User
    max log size = 51200
    registry shares = Yes
    server min protocol = NT1
    server role = standalone server
    fruit:nfs_aces = No
    idmap config * : backend = tdb
    directory name cache size = 0
    dos filemode = Yes
[Archiv]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/hdd/share/archiv
    read only = No
    vfs objects = aio_fbsd catia fruit streams_xattr noacl
    fruit:resource = stream
    fruit:metadata = stream
    fruit:encoding = native
    nfs4:chown = true
[Backup]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/hdd/share/backup
    read only = No
    fruit:locking = none
    fruit:time machine = yes
    nfs4:chown = true
[Medien]
    ea support = No
    guest ok = Yes
    level2 oplocks = No
    mangled names = no
    oplocks = No
    path = /mnt/hdd/share/medien
    read only = No
    strict locking = Yes
    nfs4:chown = true
Why does the "Medien" share have oplocks = No and level2 oplocks = No while the "Archiv" share doesn't? Both were created on the UI and the screens look absolutely identical. I cannot notice any difference accessing them.
Thanks,
Patrick
Patrick M. Hausen
Ah ... of course.
I trust all the Macs in the local LAN so it's all guest access, no ACLs and other newfangled nonsense :cool:
But I do not quite trust the player application on my Apple TV not to mess with my carefully curated metadata, so that's an NFS read-only export ...
Thanks!
anodos
Sambassador
Ah ... of course.
Thanks!
It's a matter of trying to control risks for the majority of end-users. You can override this hand-holding by adding auxiliary parameters that explicitly override the disabled parameters in the share configuration.
Patrick M. Hausen
No problem - as you can see I prefer things as simple as possible here. The engineer in me just got triggered by this assumed inconsistency.
Thanks again!
Patrick
