Philip Robar
- Jun 10, 2014
I've read the TrueNAS 12 and Mac discussions that seem to be related to the problems I seeing by searching on "smb fruit". Some reports might be related, but I didn't find this specific problem mentioned.
In a fresh install of TrueNAS 12.0 Release some of my SMB shares have fruit settings and some don't which appears to be keeping Time Machine backups from working and causes some shares to mount with no access permitted. (Red circles with a dash on all of the folders.)
The Apple SMB extensions are enabled in the SMB service GUI (By default, I didn't set it?) and the GUI setting for all of my shares are identical except for the TimeMachine share: "Default share parameters" and "Allow Guest Access". The Time Machine share has "Multi-user time machine" set and Guest access is not set.
The only the services that I have enabled are ssh, SMB and SMART.
I don't remember the order in which I created the shares was, but I'm pretty sure that the three TV shares (which have no fruit settings) were first. Deleting and recreating the three TV shares resulted in them having fruit settings and being accessible.
root@truenas[~]# testparm -a Load smb config files from /usr/local/etc/smb4.conf Loaded services file OK. WARNING: some services use vfs_fruit, others don't. Mounting them in conjunction on OS X clients results in undefined behaviour. Server role: ROLE_STANDALONE Press enter to see a dump of your service definitions # Global parameters [global] aio max threads = 2 bind interfaces only = Yes disable spoolss = Yes dns proxy = No enable web service discovery = Yes kernel change notify = No load printers = No logging = file map to guest = Bad User max log size = 51200 nsupdate command = /usr/local/bin/samba-nsupdate -g registry shares = Yes server role = standalone server server string = TrueNAS Server unix extensions = No username map = /usr/local/etc/smbusername.map username map cache time = 60 idmap config *: range = 90000001-100000000 fruit:nfs_aces = No idmap config * : backend = tdb directory name cache size = 0 dos filemode = Yes [TV2] comment = TV1 ea support = No guest ok = Yes kernel share modes = No path = /mnt/TV2/TV2 posix locking = No read only = No vfs objects = aio_fbsd streams_xattr shadow_copy_zfs ixnas nfs4:chown = true [TV1] comment = TV1 ea support = No guest ok = Yes kernel share modes = No path = /mnt/TV1/TV1 posix locking = No read only = No vfs objects = aio_fbsd streams_xattr shadow_copy_zfs ixnas nfs4:chown = true [TV3] comment = TV3 ea support = No guest ok = Yes kernel share modes = No path = /mnt/space/TV3 posix locking = No read only = No vfs objects = aio_fbsd streams_xattr shadow_copy_zfs ixnas nfs4:chown = true [Space] comment = Space ea support = No guest ok = Yes kernel share modes = No path = /mnt/space/space posix locking = No read only = No vfs objects = aio_fbsd fruit streams_xattr shadow_copy_zfs ixnas fruit:metadata = stream fruit:resource = stream nfs4:chown = true [TimeMachine] comment = Time Machine ea support = No kernel share modes = No path = /mnt/space/TimeMachine/%U posix locking = No read only = No vfs objects = aio_fbsd tmprotect fruit streams_xattr shadow_copy_zfs ixnas ixnas:default_user_quota = 1T ixnas:zfs_auto_homedir = true fruit:locking = none fruit:time machine = yes fruit:resource = stream fruit:metadata = stream nfs4:chown = true [Media] comment = Media other than Movies and TV ea support = No guest ok = Yes kernel share modes = No path = /mnt/space/media posix locking = No read only = No vfs objects = aio_fbsd fruit streams_xattr shadow_copy_zfs ixnas fruit:resource = stream fruit:metadata = stream nfs4:chown = true
