Hello :)
I have an issue with samba. All my clients are MacOS V12.1.
When interacting with (any) samba share (browsing, storing) the system logs are bombarded with entries like that:
Could anybody give me a hint?
I am currently on: TrueNAS-SCALE-22.02-RC.1-2
testparam:
2021/12/18 21:01:17.771396, 0] ../../source3/smbd/open.c:3252(smbd_calculate_maximum_allowed_access_fsp) smbd_calculate_maximum_allowed_access_fsp: Could not get acl on file FILEPATH:com.apple.metadata_kMDItemUserTags: NT_STATUS_NOT_SUPPORTED
testparam:
Load smb config files from /etc/smb4.conf lpcfg_do_global_parameter: WARNING: The "syslog only" option is deprecated Loaded services file OK. Weak crypto is allowed Server role: ROLE_STANDALONE Press enter to see a dump of your service definitions # Global parameters [global] bind interfaces only = Yes disable spoolss = Yes dns proxy = No load printers = No logging = file max log size = 5120 passdb backend = tdbsam:/var/run/samba-cache/passdb.tdb printcap name = /dev/null registry shares = Yes restrict anonymous = 2 server min protocol = SMB2 server multi channel support = No server string = Hera Filestorage idmap config * : range = 90000001 - 100000000 idmap config * : backend = tdb create mask = 0775 directory mask = 0775 [Backup] ea support = No kernel share modes = No mangled names = no path = /mnt/Tank/Backup posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = catia fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring tn:vuid = fruit:time machine max size = 0 fruit:time machine = False fruit:resource = stream fruit:metadata = stream nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True fruit:encoding = native tn:home = False tn:path_suffix = tn:purpose = NO_PRESET [JTMac] browseable = No ea support = No kernel share modes = No mangled names = no path = /mnt/Tank/Backup/JTMac/%U posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = tmprotect catia fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring zfs_core:base_user_quota = 1T zfs_core:zfs_auto_create = true tn:vuid = 8edf1be5-afab-4e2a-8df0-00a89d4c6acb fruit:time machine max size = 0 fruit:time machine = True fruit:resource = stream fruit:metadata = stream nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True fruit:encoding = native tn:home = False tn:path_suffix = %U tn:purpose = ENHANCED_TIMEMACHINE [Public] ea support = No kernel share modes = No mangled names = no path = /mnt/Tank/Public posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = catia fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring tn:vuid = fruit:time machine max size = 0 fruit:time machine = False fruit:resource = stream fruit:metadata = stream nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True fruit:encoding = native tn:home = False tn:path_suffix = tn:purpose = NO_PRESET [Privat] ea support = No kernel share modes = No mangled names = no path = /mnt/Tank/Privat posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = catia fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring tn:vuid = fruit:time machine max size = 0 fruit:time machine = False fruit:resource = stream fruit:metadata = stream nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True fruit:encoding = native tn:home = False tn:path_suffix = tn:purpose = NO_PRESET [Vault] ea support = No kernel share modes = No mangled names = no path = /mnt/Tank/Vault posix locking = No read only = No smbd max xattr size = 2097152 spotlight = Yes vfs objects = catia fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring tn:vuid = fruit:time machine max size = 0 fruit:time machine = False fruit:resource = stream fruit:metadata = stream nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True fruit:encoding = native tn:home = False tn:path_suffix = tn:purpose = NO_PRESET [Zeus] browseable = No ea support = No kernel share modes = No path = /mnt/Tank/Backup/Zeus/%U posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = tmprotect fruit streams_xattr shadow_copy_zfs nfs4acl_xattr zfs_core io_uring zfs_core:base_user_quota = 1T zfs_core:zfs_auto_create = true tn:vuid = 54cca4ad-4b85-46e7-b815-49847a5be151 fruit:time machine max size = 0 fruit:time machine = True tn:path_suffix = %U fruit:resource = stream fruit:metadata = stream tn:home = False nfs4:chown = True nfs4acl_xattr:encoding = xdr nfs4acl_xattr:xattr_name = system.nfs4_acl_xdr nfs4acl_xattr:validate_mode = False nfs4acl_xattr:nfs4_id_numeric = True tn:purpose = ENHANCED_TIMEMACHINE
