For the longest time now I've been unable to get Windows 10 to access my Freenas server (FreeNAS-11.3-U4.1) in windows explorer.  The network sees it there but will not connect to it.  I've done everything I think i can do on the windows side to get this resolved. Smb1, tcip, etc...  It just wont connect.  I can, though, connect to the dashboard GUI.
I should note that i can connect no problem with a macbook. I can access folder/ files w/o issue using a macbook.
I headed over to my freenas settings via the dashboard and under services tried to turn on SMB. It wont let me. I get the "SMB service failed to start." Message. I assume this is related to the windows 10 connection issue but i really dont know for sure.
I'm sure in trying to understand Freenas and playing with it, I probably screwed some setting up.
Can anyone point me to possible fixes for the above?
Thanks
Thanks
