SMB problem after upgrade from 8.3.1 to 9.1.1
crisman
Today I've upgraded to the newest release of Freenas and everything looks working fine but I'm always having messages on the console like this one:
Sep 6 12:05:32 freenas smbd[2329]: [2013/09/06 12:05:32.297630, 0] lib/util_sock.c:1143(matchname)
Sep 6 12:05:32 freenas smbd[2329]: matchname: host name/address mismatch: 192.168.0.87 != lfranca-8sv85n1.lusotufo.pt
Sep 6 12:05:32 freenas smbd[2329]: [2013/09/06 12:05:32.297816, 0] lib/util_sock.c:1264(get_peer_name)
Sep 6 12:05:32 freenas smbd[2329]: Matchname failed on lfranca-8sv85n1.lusotufo.pt 192.168.0.87
Could someone tell me what is this?
Regards.
Whattteva
It's complaining that your hostname of lfranca-8sv85n1.lusctufo.pt does not resolve into 192.168.0.87.
It makes sense since it looks like lusotufo.pt is an actual valid domain name and obviously that would not be able to resolve into a private 192.168.x.x IP address.
It's just warning messages that probably would not affect daily operations, so I wouldn't be too worried.
paleoN
Fix your DNS, add the appropriate entry to Host name database, under Network → Global Configuration, or turn off Hostnames lookups, under Services → CIFS.
ClayM
Sorry for the thread necromancy, but after upgrading to 9.2.1, I'm getting this error as well - it's not matching on one of my jails. It's obviously not a big deal, but any ideas?
Necromancer!!!!!!! Kill him with fire!
Actually, there's a whole bunch of SMB problems with 9.2.1. There's a bug fix version due out when the bugs are worked out.
Lusca
Just got this :
Mar 16 13:15:00 freenas smbd[88710]: [2014/03/16 13:15:00.482580,  0] ../source3/lib/util_sock.c:941(matchname)
Mar 16 13:15:00 freenas smbd[88710]:  matchname: host name/name mismatch: 192.168.1.218 != (NULL)
Mar 16 13:15:00 freenas smbd[88710]: [2014/03/16 13:15:00.482785,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Mar 16 13:15:00 freenas smbd[88710]:  matchname failed on 192.168.1.218
today-. 218 is my computer .. I cant remember that i have entered that ip from anywhere.. certainly no the name of computer obviously... any tips where i should put it to get the error go away ?
cheers
Did you read the post by paleoN that says "fix your DNS"? That means you need to fix your DNS(which isn't on FreeNAS most likely).
Lusca
yeah ok... added ip to my pc and the name to : hostname databse in the webgui..
guess that did the trick, tnx..
only this now, which i guess is ok:)
Mar 16 14:11:37 freenas notifier: Setting hostname: freenas.local.
Rogla
I'm late to the party here, just for the record....
I also got this issue. In my case there was already another Local Master on the network (domain) where I installed a new FeeNAS box.
Only one Local Master is allwed, else race conditions.
The Local Master option is enabeld by default in the CIFS service configuration in FreeNAS.
So after disabeling the Local Master in FreeNAS the nams was resolved by the original Local Master, no hostname DB in Freenas.
hansmuff
Just encountered this issue on my 9.3-stable install as well shortly after setting up my first CIFS share.
Your solution fixed it, and the documentation supports that I don't need it. Thanks!
