SMB Performance on MacOS
TravisT
In an effort to more concisely capture the problem at hand, I'm beginning a new thread instead of continuing on this one. I'm also posting in general as I'm not sure if this is storage, networking or some other unknown problem.
Problem: Perceived slow transfers over SMB sharing to Mac clients, specifically when using Adobe Lightroom.
Setup: New Mac Mini with hardwired 1GB ethernet connection to a Cisco 3750 gigabit switch to the FreeNAS box in my signature. Pool is a 4-disk RaidZ pool with 4TB disks. There is 3.84TB (38%) of free space remaining in the pool as reported by FreeNAS. I have a 2-interface LAGG setup on the FreeNAS box. The GUI reports 5.1GB RAM utilized for services and 25.4GB used (of 32GB total) for ZFS caching.
Goal: Get the most out of the system and identify bottlenecks. I want to get more performance and am willing to spend more money, but want to make sure it's spent wisely.
I think this could be a mixture of problems, but am having trouble pinpointing the bottlenecks. Based on my limited storage knowledge, everything seems to checkout individually, but something seems to be drastically reducing performance. A "real world" example is an import of about 8K photos into Adobe Lightroom (only adding them to the library without moving image files) took almost all day. Blackmagic Disk Speed Test app is showing about 18MB/s write and read to the network drive as of today. In theory, I should be seeing in the 90-100MB/s rate across a gigabit link while taking network overhead into account.
How/what can I test to help identify my bottleneck(s)?
Samuel Tai
Samuel Tai
Also, you should delete any existing .DS_Store files via find /mnt/<zpool name> -name .DS_Store -delete.
Samuel Tai
Samuel Tai
TravisT
Thanks for the replies. I'll try to address each recommendation individually, and some I want to confirm before I fire off an answer.
As for these 7 tips:
1. Lightroom catalog and preview files are on local SSD storage.
2. Mac has 32GB of RAM installed
3. See #1
4. Version is 9.2.1
5. Computer is brand new.
6. Catalog has been optimized, and a new catalog was built and tested by just adding photos in-place.
7. Automatically write changes to XMP is turned off.
TravisT
Confirmed that no .DS_Store files exist, and no new ones are being created.
What is the best way to get a generally accepted benchmark of read/write performance to start with?
App? DD from command line? Etc.
Samuel Tai
Samuel Tai
TravisT
On Catalina, here's my output:
                              SMB_NEGOTIATE                 SMBV_NEG_SMB1_ENABLED
                              SMB_NEGOTIATE                 SMBV_NEG_SMB2_ENABLED
                              SMB_NEGOTIATE                 SMBV_NEG_SMB3_ENABLED
                              SMB_VERSION                   SMB_3.02
                              SMB_SHARE_TYPE                DISK
                              SIGNING_SUPPORTED             TRUE
                              EXTENDED_SECURITY_SUPPORTED   TRUE
                              UNIX_SUPPORT                  TRUE
                              LARGE_FILE_SUPPORTED          TRUE
                              OS_X_SERVER                   TRUE
                              DFS_SUPPORTED                 TRUE
                              FILE_LEASING_SUPPORTED        TRUE
                              MULTI_CREDIT_SUPPORTED        TRUE
                              ENCRYPTION_SUPPORTED          TRUE
There is no "SIGNING_ON" attribute displayed.
I did however, run the command suggested successfully. I have tried this before, but am not sure how to check to see if it is turned off.
With default setting (delayed_ack=3)
After changing setting to delayed_ack=0:
TravisT
Ok, getting somewhere.
although I already had that in six parameters on each of my shares, I had one other entry that was supposed to increase the size of the recycle bin on that share. I removed that and restarted SMB. My speeds returned to what appear to be normal (~100MB/s read and write).
Those setting have been there for a while now (and likely through service restarts or even server restarts), so I’m skeptical, but progress is progress!
Samuel Tai
Glad you found the supposed culprit. My bag of known MacOS SMB tricks was getting empty.
TravisT
I was getting worried, because it seemed I had tried everything (including that). Fingers crossed that it's fixed now!
anodos
Sambassador
What is output of testparm -s? Recycle bin with cross_rename basically trigger a 'cp' on every unlink from a child dataset. If client behavior is particularly obnoxious, this can have a performance impact. I've considered rewriting vfs_recycle to be dataset aware (recycle bin in each dataset), but need definitive confirmation that it's an issue before I actually commit time to it.
TravisT
FreeNAS Output:
root@sannas[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
        aio max threads = 2
        bind interfaces only = Yes
        disable spoolss = Yes
        dns proxy = No
        enable web service discovery = Yes
        kernel change notify = No
        load printers = No
        logging = file
        map to guest = Bad User
        max log size = 51200
        server min protocol = SMB2_02
        server role = standalone server
        unix extensions = No
        fruit:nfs_aces = No
        idmap config * : backend = tdb
        allocation roundup size = 0
        directory name cache size = 0
        dos filemode = Yes
        include = /usr/local/etc/smb4_share.conf
[AV Library]
        access based share enum = Yes
        aio write size = 0
        ea support = No
        mangled names = illegal
        path = /mnt/globemaster/AV Library
        read only = No
        strict sync = No
        vfs objects = catia fruit streams_xattr shadow_copy_zfs ixnas
        nfs4:acedup = merge
        nfs4:chown = true
        fruit:resource = stream
        fruit:metadata = stream
[Databases]
        aio write size = 0
        ea support = No
        path = /mnt/globemaster/Databases
        read only = No
        strict sync = No
        vfs objects = catia fruit streams_xattr shadow_copy_zfs ixnas crossrename recycle
        nfs4:acedup = merge
        nfs4:chown = true
        recycle:subdir_mode = 0700
        recycle:directory_mode = 0777
        recycle:touch = yes
        recycle:keepversions = yes
        recycle:keeptree = yes
        recycle:repository = .recycle/%U
[Files]
        aio write size = 0
        ea support = No
        guest ok = Yes
        guest only = Yes
        path = /mnt/globemaster/Files
        read only = No
        strict sync = No
        nfs4:acedup = merge
        nfs4:chown = true
        recycle:touch = yes
[MacDaddy_TM]
        aio write size = 0
        browseable = No
        ea support = No
        path = /mnt/globemaster/TimeMachine/MacDaddy_TM
        read only = No
        strict sync = No
        vfs objects = catia fruit streams_xattr ixnas
        nfs4:acedup = merge
        nfs4:chown = true
        fruit:volume_uuid = 782b0b2a-c0c2-4cd6-9392-e1a2cbd003e6
        fruit:time machine = yes
[MacShare]
        aio write size = 0
        ea support = No
        path = /mnt/globemaster/MacShare
        read only = No
        strict sync = No
        nfs4:acedup = merge
        nfs4:chown = true
        recycle:touch = yes
[Media]
        aio write size = 0
        ea support = No
        guest ok = Yes
        guest only = Yes
        path = /mnt/globemaster/Media
        read only = No
        strict sync = No
        nfs4:acedup = merge
        nfs4:chown = true
        recycle:touch = yes
[Reference]
        aio write size = 0
        ea support = No
        guest ok = Yes
        guest only = Yes
        path = /mnt/globemaster/Reference
        read only = No
        strict sync = No
        nfs4:acedup = merge
        nfs4:chown = true
        recycle:touch = yes
[Software]
        aio write size = 0
        ea support = No
        guest ok = Yes
        guest only = Yes
        path = /mnt/globemaster/Software
        read only = No
        nfs4:acedup = merge
        nfs4:chown = true
TravisT
I'm still having weird issues in Lightroom, but have some work to do before I can confirm it's FreeNAS related or Lightroom related. I am curious if you see anything out of place in the above output. It would not surprise me if there is configuration on FreeNAS that is incorrect or could be tweaked.
If I understand correctly, it seems that enabling the recycle bin may cause problems. I'll be honest, the recycle bin does not seem to work correctly on any of my datasets, so if disabling that will be beneficial, I'm more than willing to try it out.
TravisT
Ok, so this problem keeps coming back for some reason. It seems that restarting the SMB service remedies the problem temporarily. As a side note, I did turn autotune on at one point in trying to resolve these problems, but I didn't remove the parameters left in place by it.
Any ideas?
Below are the in-place tunables:
ObiTobi
I'm not sure if I understand all, but which problems do you have yet? I think your performance problems are gone after you have set "signing to off".
What are your problems with LR?
TravisT
The performance problems appeared to be gone after setting "strict sync = no", however I did have that set on each dataset and the dataset in question already. I also restarted the SMB service after doing this. The easiest measurable feedback I could get was by using BlackMagic Disk Speed Test on the dataset in question. Just performed a clean run with the below results:
After resetting SMB service on FreeNAS and re-running test:
The only change is restarting the SMB service. This could have been a fluke in the original results and thinking the "strict sync = no" was the fix acton. As an aside, the Lightroom issues were the most noticeable at the time, as I was doing a lot of work within Lightroom. When transfer speeds are showing "normal", my Lightroom performance is what I would expect. When I notice slow Lightroom performance, I'm also seeing slow performance on the BlackMagic results, so I'm using that as the baseline tool at this point, even though it may not be the best tool.
