I am new to TrueNas and in here.
I have build a server running TrueNAS-SCALE-22.02.4.
I run Plex in "Apps" and I have create at dataset with ACL on it, so fare to good.
Then I have create a SMB share with my contents, I can access it from my main computer, with user "Brian" created in TrueNas, as a network dreve. On my main computer I have map the drev, here I can add more content, and Plex see it and it works.
Then I have made a VM inside TrueNas (windows 2022) where I use a other user "windows" and this user can see and create file/folder in the same smb share as Brian.
But Plex can´t scan the same folder and see the contents???
The only differents is the owner of the file.!
Main computer where it works. "Brian" is owner"
Windows 2022 where it does work "Windows" is owner
The "windows" user have the same rights as "Brian"
I can see that this is a
