SMB not starting
Servman
Hi All,
Im hope someone will be able to help me with this,
im running FreeNAS 11-U3
and smb just stopped working and will not start
see error below.
Request Method: POST
Request URL: http://192.168.1.101/services/cifs/
Software Version: FreeNAS-11.0-U3 (c5dcf4416)
Exception Type: ServiceFailed
Exception Value:
<django.utils.functional.lazy.<locals>.__proxy__ object at 0x81661f4e0>
Exception Location: ./freenasUI/services/forms.py in save, line 265
Server time: Sun, 17 Sep 2017 07:08:11 +1000
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
  39.  response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
  249.  response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
  178.  response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
  162.  return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  23.  return view_func(request, *args, **kwargs)
File "./freenasUI/services/views.py" in services_cifs
  208.  form.save()
File "./freenasUI/services/forms.py" in save
  265.  "cifs", _("The SMB service failed to reload.")
Exception Type: ServiceFailed at /services/cifs/
Exception Value: <django.utils.functional.lazy.<locals>.__proxy__ object at 0x81661f4e0>
Request information
GET
No GET data
POST
Variable
Value
__all__ ''
cifs_srv_netbiosname 'nas-home'
cifs_srv_netbiosalias 'nas-home'
cifs_srv_workgroup 'WORKGROUP'
cifs_srv_description 'nas-home Server'
cifs_srv_doscharset 'CP437'
cifs_srv_unixcharset 'UTF-8'
cifs_srv_loglevel '1'
cifs_srv_localmaster 'on'
cifs_srv_timeserver 'on'
cifs_srv_guest 'nobody'
cifs_srv_filemask ''
cifs_srv_dirmask ''
cifs_srv_smb_options 'valid users = @smbshare'
cifs_srv_unixext 'on'
cifs_srv_zeroconf 'on'
cifs_srv_hostlookup 'on'
cifs_srv_min_protocol ''
cifs_srv_max_protocol 'SMB3'
cifs_srv_allow_execute_always 'on'
cifs_srv_obey_pam_restrictions 'on'
cifs_srv_bindip '192.168.1.101'
idmap_tdb_range_low '90000001'
idmap_tdb_range_high '100000000'
__form_id 'dialogForm_'
FILES
No FILES data
COOKIES
Variable
Value
stay_login '0'
csrftoken 'XlVN35IdjClRJL10NA7i1Nu0GycyPSlsrczNcKrpoWsOumfm0mKVUeyGHHd9MVH7'
fntreeSaveStateCookie 'root'
sessionid 'dvrfyuhoymjrfxdi4jbpbw55oel8x5hi'
META
Variable Value
this happens when i try an save.
im hoping some can help or i may need to rebuild my NAS if not :(
Regards
What hardware are you running?
Servman
I have been able to fix the issue by doing a factory restore and then upload my config.
but i would like to know what the cause could have been.
CPU amd phenom ii
Ram: 8GB ram
please advise if this information is what you need or if theirs more needed?
Regards
Stux
Servman
It could've been a bug, but we'll probably never know now
the only thing that had changed is i had my drive at 96 - 99% filled could that have been the issue?
but if it happens again i will leave it and get in contact.
Servman
Hi stux,
I have had samba stop working again and i thing you are right and its a bug.
Hope you can hope?
Sent from my SM-G955F using Tapatalk
SweetAndLow
Sweet'NASty
Your best option is to create a debug file and post it here.
Servman
It has resolved it self after i had deleted some file, looks to be when theres on 86gb left samba stops working once there is more storage it starts to work as normal
Sounds like you need to stop filling your pool.
Servman
I agree with tou there bit on another note samba still should not stop working.
And when you does you can access the pool? Un less you hace an other way to access the data to clean it up and remove data.
Let me be clear: You cannot fill your pool, otherwise your day will be ruined. Samba not working would be the least of your problems.
Servman
By not explaining your self dose not help the freenas community?
nojohnny101
You could do a search by yourself to see why filling your pool above even 80% is not recommended. Doing a quick one I got these results:
freenas filling pool beyond 80%
There is a reason that a warning system has been built into FreeNAS for ages to warn users of this.
