SMB (nmbd actually) not starting on fresh install 11.2 U4
zjeff222
Newbie
I did a fresh install on FreenNAS and did not imported the configuration file. I imported the pool and added a share. I found out that nmbd is having trouble. Here is the log:
[2019/05/28 20:36:32.564771, 0] ../source3/lib/util_sock.c:396(open_socket_in)
bind failed on port 137 socket_addr = 192.168.0.255.
Error = Can't assign requested address
[2019/05/28 20:36:32.564839, 0] ../source3/nmbd/nmbd_subnetdb.c:127(make_subnet)
nmbd_subnetdb:make_subnet()
Failed to open nmb bcast socket on interface 192.168.0.255 for port 137. Error was Can't assign requested address
[2019/05/28 20:36:32.564868, 0] ../lib/util/become_daemon.c:124(exit_daemon)
exit_daemon: STATUS=daemon failed to start: NMBD failed when creating subnet lists, error code 13
I wonder if it is normal for the IP to end with 255 (server ip is 192.168.0.95)
The reason I did a fresh install was because I had the same problem (didn't check the log then, but other symptoms were similar). So could be something on the network?? Anyone knows what could cause this?
Thank you.
zjeff222
Newbie
no, but I figured out that I don't use whatever it is that nmbd does. thanks
