smb.d core dump repeatedly, 13U4, 2 different systems (same files)
jenksdrummer
2 systems, same core dumps. I guess same admin being a potential factor but I don't sense I am doing anything odd here.
Supermicro 11th gen; Silver 4210 192GB ECC RAM, using integrated 3008 SAS controller
Created pool
- 6x Mirror VDEV WD Gold 10TB
- 1x Mirror Special VDEV Samsung 970 Evo Plus 1TB NVMe
- Single Cache VDEV Samsung 970 Evo Plus 1TB NVMe
Set SHA512
Set 1M Stripe Size (mostly archival data)
Set Small IO 16K
Compression LSTD
Create sub dataset "shares"
- Create sub datasets for each share
SMB enabled, SMB min version 3 set
Data copied via robocopy from windows server 2019. This after I had copied around 6TB of data, and was running another pull of robocopy to make sure there wasn't any lingering/changed files before decom of the WS2019 box.
Other system is a Supermicro 5028D; Xeon-D something, 128GB ECC, Intel/on-board SATA
Created pool
- 1x Z2 VDEV 6x WD Red SATA SSD 4TB
- 2x Mirror Special VDEV Samsung 970 Evo Plus 1TB NVMe
Set SHA512
Set 1M Stripe Size
Not set small IO as I was...
Deduplication was on
Compression was set as LZ4
This 2nd box became the WS2019 box, no issues while running WS2019. Used Supermicro/LSI 3108 while WS2019 but removed while TrueNAS. System is again back to TrueNAS and about to start copying over data but want to see if I can find out what the issue is with SMB.D
anodos
Sambassador
Created pool
Set SHA512
Set Small IO 16K
Compression LSTD
Created pool
Set SHA512
Set 1M Stripe Size
Can you PM me a debug and the corefile. This is most likely an issue already fixed for U5.
