can anyone help me with the following smart test results? Overall seems to have passed? But the zfs pool is degraded. And not sure if "Self test Execution status:" means the last test was cancelled?
smartctl -a /dev/da1
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD100EFAX-68LHPN0
Serial Number: 1DGPHVAZ
LU WWN Device Id: 5 000cca 26cc9c74a
Firmware Version: 83.H0A83
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jul 13 12:54:57 2020 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 93) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1203) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0004 129 129 054 Old_age Offline - 112
3 Spin_Up_Time 0x0007 154 154 024 Pre-fail Always - 417 (Average 439)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 3530
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 098 098 000 Old_age Always - 18889
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2925
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 097 097 000 Old_age Always - 4154
193 Load_Cycle_Count 0x0012 097 097 000 Old_age Always - 4154
194 Temperature_Celsius 0x0002 196 196 000 Old_age Always - 33 (Min/Max 22/54)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 8
SMART Error Log Version: 1
ATA Error Count: 8 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 8 occurred at disk power-on lifetime: 18642 hours (776 days + 18 hours)
When the command that caused the error occurred, the device was active or idle .
ER ST SC SN CL CH DH
84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 04 00 99 ff 3f 40 00 37d+10:53:13.067 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 37d+10:53:13.059 READ LOG EXT
60 04 00 99 ff 3f 40 00 37d+10:53:13.030 READ FPDMA QUEUED
ef 10 02 00 00 00 00 00 37d+10:53:12.933 SET FEATURES [Enable SATA feature]
Error 7 occurred at disk power-on lifetime: 18642 hours (776 days + 18 hours)
60 04 00 99 ff 3f 40 00 37d+10:53:13.059 READ FPDMA QUEUED
ef 02 00 00 00 00 00 00 37d+10:53:12.930 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 00 00 37d+10:53:12.927 SET FEATURES [Enable read look-ahea d]
ef 03 46 00 00 00 00 00 37d+10:53:12.924 SET FEATURES [Set transfer mode]
Error 6 occurred at disk power-on lifetime: 18642 hours (776 days + 18 hours)
60 01 00 d7 ff 3f 40 00 37d+10:53:12.601 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 37d+10:53:12.576 READ LOG EXT
60 10 10 90 fc 3f 40 00 37d+10:53:12.569 READ FPDMA QUEUED
60 10 08 90 fa 3f 40 00 37d+10:53:12.569 READ FPDMA QUEUED
Error 5 occurred at disk power-on lifetime: 18642 hours (776 days + 18 hours)
60 10 00 90 02 40 40 00 37d+10:53:12.576 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 37d+10:53:12.568 READ LOG EXT
Error 4 occurred at disk power-on lifetime: 18642 hours (776 days + 18 hours)
60 10 00 90 02 40 40 00 37d+10:53:12.568 READ FPDMA QUEUED
60 10 10 90 fc 3f 40 00 37d+10:53:12.560 READ FPDMA QUEUED
60 10 08 90 fa 3f 40 00 37d+10:53:12.560 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 37d+10:53:12.560 READ LOG EXT
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Short offline Interrupted (host reset) 50% 18876 -
# 2 Short offline Interrupted (host reset) 50% 18852 -
# 3 Extended offline Interrupted (host reset) 90% 18848 -
# 4 Short offline Interrupted (host reset) 90% 18828 -
# 5 Short offline Interrupted (host reset) 50% 18780 -
# 6 Short offline Interrupted (host reset) 50% 18756 -
# 7 Short offline Interrupted (host reset) 90% 18732 -
# 8 Short offline Interrupted (host reset) 50% 18708 -
# 9 Short offline Completed without error 00% 18684 -
#10 Extended offline Interrupted (host reset) 90% 18684 -
#11 Short offline Completed without error 00% 18660 -
#12 Short offline Completed without error 00% 18636 -
#13 Short offline Completed without error 00% 18612 -
#14 Short offline Completed without error 00% 18588 -
#15 Short offline Completed without error 00% 18564 -
#16 Extended offline Completed without error 00% 18562 -
#17 Short offline Completed without error 00% 18492 -
#18 Short offline Completed without error 00% 18468 -
#19 Short offline Completed without error 00% 18444 -
#20 Short offline Completed without error 00% 18420 -
#21 Short offline Completed without error 00% 18396 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
