Jailer
Not strong, but bad
- Sep 12, 2014
Ok I have my smart testing schedule set up exactly as recommended by Cyberjock in his guide. I have 6-3TB greens in a RAIDZ2 pool. The first drive in the array, da0, is not performing scheduled smart tests. The remaining 5 all run the tests as scheduled. I can manually run all smart test from the CLI on da0 and they all complete successfully and are logged correctly on the drive.
The only peculiarity I can find is that da0 does not have a serial number listed in the drives tab. See the attached pic below. da0 is also the only drive that shows up at boot on my on board LSI controller on the board listed in my sig. It has been flashed to IT mode with the correct firmware and all drives have had the wdidle3 utility run on them to set to 300 seconds.
Any insight as to why this may be happening or how to fix it so I don't have to manually babysit one drive?
