turment
- Feb 3, 2020
I have noticed that the SMART service is not working, even if enabled at startup.
Whenever I try to switch on by GUI, I receive the pop up "S.M.A.R.T. service failed to start."
On the physical console, it appears: "<date + time + machine name> smartd[6941]: Configuration file /usr/local/etc/smartd.conf has fatal syntax errors."
It contains:
Help. :)
It contains:
I have no USB devices: ada0-3 are the pool and ada4-5 are the bootable disks in mirror./dev/ada0 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py root
/dev/ada1 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py root
/dev/ada2 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py root
/dev/ada3 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py root
/dev/ada5 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py root
/dev/ada4 -a -d removable -n never -W 0,0,0 -m root -M exec /usr/local/libexec/smart_alert.py
Help. :)
