Hi everyone!
I'm fairly new to TrueNAS after flashing it onto my old linux NAS.
I recently encountered some read errors on one disk. I filed for an RMA, but I have some questions about operations to do in the meantime. I did see the TrueNAS disk replacement document at https://www.truenas.com/docs/core/coretutorials/storage/disks/diskreplace/ and had a couple additional questions.
0. Questions
1. What happened
2. Hardware Info
Let me know if you need more specific info about anything! Thanks!
0. Questions
- Despite self-test number 1 and 2 having status "Completed: read failure", I see that "SMART overall-health self-assesment test results: PASSED" and that Raw_Read_Error_Rate is still 0
- Does indicate some bad sectors, but no actual mechanical issues? Can I safely continue using the disk while I await RMA?
- Is it safe to run the machine with one disk offline while awaiting a replacement disk? (pool is raidz1 with 4 disks and a single vdev)
- Is there anything I need to do to ensure the bad sectors are marked as such?
- Should I scrub the pool before or after taking the faulty disk offline? The last scrub was a couple weeks ago, so the ZFS pool status still shows 0 errors.
- I was going to order a replacement disk while I wait for the RMA to process. This means after RMA is processed, I'll probably have an extra disk from the RMA. I'm still new to ZFS, and I've seen varied info about this online, but, given my storage pool that's raidz1 with 4 disks on a single vdev:
- Can I expand my pool to 5 disks in-place? Or do I need to completely reformat the vdev / pool to do that?
- If I can't expand the vdev in-place from 4 to 5 disks in raidz1, is there a number of additional disks that would allow me to do so?
- If I can, will I need to manually tell it to rebalance data evenly across the new disks?
1. What happened
- I got an email notification that self-test error count has incremented:
CRITICAL
Device: /dev/ada3, Self-Test Log error count increased from 0 to 1.
2023-07-01 00:58:59
- I checked the smart log with `smartctl -a /dev/ada3`
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68L0BN1
Serial Number: WD-WX72D507JU0F
LU WWN Device Id: 5 0014ee 212c5502c
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5700 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jul 1 12:06:51 2023 PDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: ( 4244) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 696) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 228 196 021 Pre-fail Always - 7591
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 285
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19694
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 248
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 81
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 13328
194 Temperature_Celsius 0x0022 122 097 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 10% 19683 3130118592
# 2 Short offline Completed without error 00% 19659 -
# 3 Short offline Completed without error 00% 19635 -
# 4 Short offline Completed without error 00% 19611 -
# 5 Short offline Completed without error 00% 19587 -
# 6 Short offline Completed without error 00% 19563 -
# 7 Short offline Completed without error 00% 19539 -
# 8 Short offline Completed without error 00% 19515 -
# 9 Short offline Completed without error 00% 19491 -
#10 Short offline Completed without error 00% 19467 -
#11 Short offline Completed without error 00% 19443 -
#12 Short offline Completed without error 00% 19419 -
#13 Extended offline Completed without error 00% 19396 -
#14 Short offline Completed without error 00% 19371 -
#15 Short offline Completed without error 00% 19347 -
#16 Short offline Completed without error 00% 19323 -
#17 Short offline Completed without error 00% 19299 -
#18 Short offline Completed without error 00% 19275 -
#19 Short offline Completed without error 00% 19251 -
#20 Short offline Completed without error 00% 19227 -
#21 Short offline Completed without error 00% 19204 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
- I filed an RMA for the disk (hardware details in section below)
- I ran a long smart test on the offending disk with `smartctl -t /dev/ada3`
- One day later after the long test completes, I check the smart log again with `smartctl -a /dev/ada3`
Local Time is: Sun Jul 2 17:03:53 2023 PDT
was never started.
command.
power-saving mode.
9 Power_On_Hours 0x0032 073 073 000 Old_age Always - 19723
194 Temperature_Celsius 0x0022 121 097 000 Old_age Always - 31
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 88
No Errors Logged
# 1 Extended offline Completed: read failure 10% 19711 3130073184
# 2 Short offline Completed: read failure 10% 19683 3130118592
# 3 Short offline Completed without error 00% 19659 -
# 4 Short offline Completed without error 00% 19635 -
# 5 Short offline Completed without error 00% 19611 -
# 6 Short offline Completed without error 00% 19587 -
# 7 Short offline Completed without error 00% 19563 -
# 8 Short offline Completed without error 00% 19539 -
# 9 Short offline Completed without error 00% 19515 -
#10 Short offline Completed without error 00% 19491 -
#11 Short offline Completed without error 00% 19467 -
#12 Short offline Completed without error 00% 19443 -
#13 Short offline Completed without error 00% 19419 -
#14 Extended offline Completed without error 00% 19396 -
#15 Short offline Completed without error 00% 19371 -
#16 Short offline Completed without error 00% 19347 -
#17 Short offline Completed without error 00% 19323 -
#18 Short offline Completed without error 00% 19299 -
#19 Short offline Completed without error 00% 19275 -
#20 Short offline Completed without error 00% 19251 -
#21 Short offline Completed without error 00% 19227 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
- Note that the LBA of the first error on the extended offline test and short offline test are different, which seems bad
2. Hardware Info
- Storage pool contains:
- 4x WD red plus 6tb
- Boot pool contains two nvme ssds
- Running TrueNAS-13.0-U4
- CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
- 16 gb of ram, can look up timings or model if needed
- Can look up motherboard if needed
- zpool status -v
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:01 with 0 errors on Sat Jul 1 03:45:01 2023
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
nvd0p2 ONLINE 0 0 0
nvd1p2 ONLINE 0 0 0
errors: No known data errors
pool: wd_reds_6g_x4
state: ONLINE
scan: scrub repaired 0B in 06:03:46 with 0 errors on Sun Jun 11 06:03:46 2023
wd_reds_6g_x4 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/8b11663a-e8b1-11ed-9657-e0d55e2ccd56 ONLINE 0 0 0
gptid/8b24cb3b-e8b1-11ed-9657-e0d55e2ccd56 ONLINE 0 0 0
gptid/8b1bd536-e8b1-11ed-9657-e0d55e2ccd56 ONLINE 0 0 0
gptid/8b03e3c9-e8b1-11ed-9657-e0d55e2ccd56 ONLINE 0 0 0
state: ONLINE
nvd0p2 ONLINE 0 0 0
nvd1p2 ONLINE 0 0 0
pool: wd_reds_6g_x4
state: ONLINE
