winnielinnie
- Oct 22, 2019
You can tell I twisted my brain into several knots trying to muster a title that can describe my question...
Is it possible to create a single periodic snapshot task that follows the same principles of "smart" backups?
For example, from a single task...
This would theoretically yield you with about a couple dozen daily snapshots that are destroyed on a 4-week conveyor belt, while a couple of them "survive" for another 6 months. Of the eventual handful that survive for another six months, some will be destroyed, while a few will survive for another two years. Only a couple of those from the group that survives for 2 years will be allowed to live for another 10 years. Think of it as snapshot pyramid from a single task.
I'm not sure what the terminology for this procedure is, but I recall backup and filesystem snapshot software (not TrueNAS- nor ZFS-related) using terms like "smart" or "staggered" backups.
Is this possible with TrueNAS, or must you configure a different Task for each expiration lifespan? (I'm hoping it's possible with the former, as it requires fewer overall tasks, which is more elegant.)
- Snapshots are created daily and marked with a 4 weeks expiration
- Of these a couple of them are tagged for a longer expiration of 6 months
- Of these, a couple of them are tagged for an even longer expiration of 2 years
- And finally of these, a couple of them are tagged for an even longer expiration of 10 years
