I've got 8 drives on a 3Ware RAID controller. I put them all in JBOD mode. The card does it's own SMART monitoring. I heard somewhere that I should disable SMART on FreeNAS and let the 3Ware card handle it, because it can cause problems if they are both doing it.
Is this true? If so, do I just go edit each drive in FreeNAS and uncheck the SMART monitoring checkbox?
