zoo
 - Jul 11, 2011
Hi all,
A few days ago I recieved an automated email containing:
The following warning/error was logged by the smartd daemon:
Device: /dev/ada0, unable to open device
I rebooted the machine and everything seemed normal again. Then I completed a backup and ran extended smart tests on every drive in the array. I had been running short ones in the past. While none of the drives "failed" the test, a few of them have ATA errors logged. Should I be worried? I do have two new spare drives for this occasion tested and ready to go but I'm not sure if I'm just being paranoid since the errors were logged thousands of hours prior.
I attached the smartctl logs for the 6 drives below if anyone has insight..thanks.
/# smartctl -a /dev/ada0
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family:     SAMSUNG SpinPoint F3 EG
Device Model:     SAMSUNG HD203WI
Firmware Version: 1AN10003
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 6
Local Time is:    Fri Nov 23 18:12:28 2012 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(26280) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 438) minutes.
SCT capabilities: 	       (0x003f)	SCT Status supported.
					SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       678
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       23926
  3 Spin_Up_Time            0x0023   061   061   025    Pre-fail  Always       -       11927
  4 Start_Stop_Count        0x0032   094   094   000    Old_age   Always       -       6567
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   252   252   051    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       13302
 10 Spin_Retry_Count        0x0032   252   252   051    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   252   252   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       138
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       3858
192 Power-Off_Retract_Count 0x0022   252   252   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       23 (Min/Max 16/29)
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   252   252   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   100   100   000    Old_age   Always       -       114
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       234
223 Load_Retry_Count        0x0032   252   252   000    Old_age   Always       -       0
225 Load_Cycle_Count        0x0032   094   094   000    Old_age   Always       -       70640
SMART Error Log Version: 1
ATA Error Count: 71 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 71 occurred at disk power-on lifetime: 2650 hours (110 days + 10 hours)
  ER ST SC SN CL CH DH
  84 51 20 00 00 00 e0  Error: ICRC, ABRT 32 sectors at LBA = 0x00000000 = 0
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 10 10 00 00 e0 00      00:00:00.110  READ DMA
  c8 00 10 80 00 00 e0 00      00:00:00.110  READ DMA
  c8 00 10 80 00 00 e0 00      00:00:00.109  READ DMA
Error 70 occurred at disk power-on lifetime: 2650 hours (110 days + 10 hours)
  84 51 90 00 00 00 e0  Error: ICRC, ABRT 144 sectors at LBA = 0x00000000 = 0
  c8 00 10 80 00 00 e0 00      00:00:00.108  READ DMA
Error 69 occurred at disk power-on lifetime: 2650 hours (110 days + 10 hours)
Error 68 occurred at disk power-on lifetime: 2650 hours (110 days + 10 hours)
  25 00 01 af 88 e0 40 00      00:00:00.108  READ DMA EXT
Error 67 occurred at disk power-on lifetime: 2650 hours (110 days + 10 hours)
  25 00 01 af 88 e0 40 00      00:00:00.107  READ DMA EXT
# 1  Extended offline    Completed without error       00%     13288         -
# 2  Short offline       Completed without error       00%     13280         -
# 3  Short offline       Completed without error       00%     13253         -
# 4  Short offline       Completed without error       00%     10299         -
# 5  Short offline       Completed without error       00%     10131         -
# 6  Short offline       Completed without error       00%      9964         -
# 7  Short offline       Completed without error       00%      9916         -
# 8  Short offline       Completed without error       00%      9764         -
# 9  Short offline       Completed without error       00%      9596         -
#10  Short offline       Completed without error       00%      9428         -
#11  Short offline       Completed without error       00%      9260         -
#12  Short offline       Completed without error       00%      9188         -
#13  Short offline       Completed without error       00%      9020         -
#14  Short offline       Completed without error       00%      8852         -
#15  Short offline       Completed without error       00%      8684         -
#16  Short offline       Completed without error       00%      8516         -
#17  Short offline       Completed without error       00%      8468         -
#18  Short offline       Completed without error       00%      8301         -
#19  Short offline       Completed without error       00%      8133         -
#20  Short offline       Completed without error       00%      7965         -
#21  Short offline       Completed without error       00%      7797         -
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
    1        0        0  Completed [00% left] (0-65535)
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
/# smartctl -a /dev/ada1
Model Family:     SAMSUNG SpinPoint F4 EG (AFT)
Device Model:     SAMSUNG HD204UI
Firmware Version: 1AQ10001
ATA Version is:   8
Local Time is:    Fri Nov 23 18:12:49 2012 EST
==> WARNING: Using smartmontools or hdparm with this
drive may result in data loss due to a firmware bug.
****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ******
Buggy and fixed firmware report same version number!
See the following web pages for details:
http://knowledge.seagate.com/articles/en_US/FAQ/223571en
http://sourceforge.net/apps/trac/smartmontools/wiki/SamsungF4EGBadBlocks
					was never started.
					been run.
data collection: 		(19860) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 331) minutes.
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       1
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       18103
  3 Spin_Up_Time            0x0023   067   044   025    Pre-fail  Always       -       10060
  4 Start_Stop_Count        0x0032   095   095   000    Old_age   Always       -       5976
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       10652
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       96
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       355
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       7696
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       25 (Min/Max 17/34)
199 UDMA_CRC_Error_Count    0x0036   100   100   000    Old_age   Always       -       7
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       39
225 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       6003
ATA Error Count: 1
Error 1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  84 51 00 00 00 00 00
  ec 00 01 01 00 00 00 00      00:00:00.177  IDENTIFY DEVICE
  08 00 01 01 00 00 00 00      00:00:00.177  DEVICE RESET
  00 00 01 01 00 00 40 00      00:00:00.155  NOP [Abort queued commands]
  29 ff 01 af 82 e0 40 00      00:00:00.106  READ MULTIPLE EXT
# 1  Extended offline    Completed without error       00%     10648         -
# 2  Short offline       Completed without error       00%     10602         -
# 3  Short offline       Completed without error       00%      7646         -
# 4  Short offline       Completed without error       00%      7479         -
# 5  Short offline       Completed without error       00%      7313         -
# 6  Short offline       Completed without error       00%      7265         -
# 7  Short offline       Completed without error       00%      7113         -
# 8  Short offline       Completed without error       00%      6945         -
# 9  Short offline       Completed without error       00%      6777         -
#10  Short offline       Completed without error       00%      6609         -
#11  Short offline       Completed without error       00%      6537         -
#12  Short offline       Completed without error       00%      6369         -
#13  Short offline       Completed without error       00%      6201         -
#14  Short offline       Completed without error       00%      6033         -
#15  Short offline       Completed without error       00%      5865         -
#16  Short offline       Completed without error       00%      5817         -
#17  Short offline       Completed without error       00%      5650         -
#18  Short offline       Completed without error       00%      5482         -
#19  Short offline       Completed without error       00%      5314         -
#20  Short offline       Completed without error       00%      5146         -
#21  Short offline       Completed without error       00%      5074         -
/# smartctl -a /dev/ada2
ATA Version is:   8
Local Time is:    Fri Nov 23 18:13:01 2012 EST
					was never started.
					been run.
data collection: 		(20580) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 343) minutes.
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       86
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       18722
  3 Spin_Up_Time            0x0023   067   045   025    Pre-fail  Always       -       10017
  4 Start_Stop_Count        0x0032   095   095   000    Old_age   Always       -       5760
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       10663
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       78
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       347
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       7144
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       24 (Min/Max 16/35)
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       42
225 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       5782
No Errors Logged
# 1  Extended offline    Completed without error       00%     10660         -
# 2  Short offline       Completed without error       00%     10614         -
# 3  Short offline       Completed without error       00%      7648         -
# 4  Short offline       Completed without error       00%      7480         -
# 5  Short offline       Completed without error       00%      7312         -
# 6  Short offline       Completed without error       00%      7264         -
# 7  Short offline       Completed without error       00%      7112         -
# 8  Short offline       Completed without error       00%      6944         -
# 9  Short offline       Completed without error       00%      6776         -
#10  Short offline       Completed without error       00%      6608         -
#11  Short offline       Completed without error       00%      6536         -
#12  Short offline       Completed without error       00%      6368         -
#13  Short offline       Completed without error       00%      6200         -
#14  Short offline       Completed without error       00%      6032         -
#15  Short offline       Completed without error       00%      5864         -
#16  Short offline       Completed without error       00%      5816         -
#17  Short offline       Completed without error       00%      5648         -
#18  Short offline       Completed without error       00%      5480         -
#19  Short offline       Completed without error       00%      5312         -
#20  Short offline       Completed without error       00%      5144         -
#21  Short offline       Completed without error       00%      5072         -
/# smartctl -a /dev/ada3
ATA Version is:   8
Local Time is:    Fri Nov 23 18:13:08 2012 EST
					was never started.
					been run.
data collection: 		(26340) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 439) minutes.
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       402
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       23985
  3 Spin_Up_Time            0x0023   060   060   025    Pre-fail  Always       -       12159
  4 Start_Stop_Count        0x0032   094   094   000    Old_age   Always       -       6459
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       13166
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       137
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       3992
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       25 (Min/Max 18/30)
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       219
225 Load_Cycle_Count        0x0032   094   094   000    Old_age   Always       -       69718
No Errors Logged
# 1  Extended offline    Completed without error       00%     13164         -
# 2  Short offline       Completed without error       00%     13116         -
# 3  Short offline       Completed without error       00%     10159         -
# 4  Short offline       Completed without error       00%      9992         -
# 5  Short offline       Completed without error       00%      9825         -
# 6  Short offline       Completed without error       00%      9777         -
# 7  Short offline       Completed without error       00%      9625         -
# 8  Short offline       Completed without error       00%      9457         -
# 9  Short offline       Completed without error       00%      9289         -
#10  Short offline       Completed without error       00%      9121         -
#11  Short offline       Completed without error       00%      9049         -
#12  Short offline       Completed without error       00%      8881         -
#13  Short offline       Completed without error       00%      8713         -
#14  Short offline       Completed without error       00%      8545         -
#15  Short offline       Completed without error       00%      8377         -
#16  Short offline       Completed without error       00%      8329         -
#17  Short offline       Completed without error       00%      8161         -
#18  Short offline       Completed without error       00%      7993         -
#19  Short offline       Completed without error       00%      7825         -
#20  Short offline       Completed without error       00%      7657         -
#21  Short offline       Completed without error       00%      7586         -
smartctl -a /dev/ada4
ATA Version is:   8
Local Time is:    Fri Nov 23 18:13:18 2012 EST
					was never started.
					been run.
data collection: 		(21360) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 356) minutes.
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0026   056   056   000    Old_age   Always       -       19432
  3 Spin_Up_Time            0x0023   066   066   025    Pre-fail  Always       -       10341
  4 Start_Stop_Count        0x0032   094   094   000    Old_age   Always       -       6704
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       10972
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       139
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       21681288
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       9077
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       25 (Min/Max 18/35)
199 UDMA_CRC_Error_Count    0x0036   097   097   000    Old_age   Always       -       1672
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       150
225 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       6728
ATA Error Count: 3
Error 3 occurred at disk power-on lifetime: 366 hours (15 days + 6 hours)
  84 51 01 7f 02 40 e0  Error: ICRC, ABRT at LBA = 0x0040027f = 4194943
  ca 00 08 78 02 40 e0 02      00:01:56.947  WRITE DMA
  ea 00 00 00 00 00 40 02      00:01:56.947  FLUSH CACHE EXT
  35 00 20 a8 bd 40 40 02      00:01:56.947  WRITE DMA EXT
  35 00 10 58 8b 40 40 02      00:01:56.947  WRITE DMA EXT
Error 2 occurred at disk power-on lifetime: 365 hours (15 days + 5 hours)
  84 51 01 97 03 40 e0  Error: ICRC, ABRT at LBA = 0x00400397 = 4195223
  ca 00 08 90 03 40 e0 02      00:01:19.156  WRITE DMA
  ca 00 08 90 01 40 e0 02      00:01:19.156  WRITE DMA
  ea 00 00 00 00 00 40 02      00:01:19.156  FLUSH CACHE EXT
  35 00 08 70 a1 40 40 02      00:01:19.156  WRITE DMA EXT
Error 1 occurred at disk power-on lifetime: 365 hours (15 days + 5 hours)
  84 51 01 4f 02 40 e0  Error: ICRC, ABRT at LBA = 0x0040024f = 4194895
  ca 00 08 48 02 40 e0 02      00:01:19.111  WRITE DMA
  ea 00 00 00 00 00 40 02      00:01:19.111  FLUSH CACHE EXT
  35 00 30 08 74 40 40 02      00:01:19.111  WRITE DMA EXT
  35 00 10 68 45 40 40 02      00:01:19.111  WRITE DMA EXT
# 1  Extended offline    Completed without error       00%     10969         -
# 2  Short offline       Completed without error       00%     10922         -
# 3  Short offline       Completed without error       00%      7961         -
# 4  Short offline       Completed without error       00%      7794         -
# 5  Short offline       Completed without error       00%      7626         -
# 6  Short offline       Completed without error       00%      7578         -
# 7  Short offline       Completed without error       00%      7426         -
# 8  Short offline       Completed without error       00%      7258         -
# 9  Short offline       Completed without error       00%      7090         -
#10  Short offline       Completed without error       00%      6922         -
#11  Short offline       Completed without error       00%      6850         -
#12  Short offline       Completed without error       00%      6682         -
#13  Short offline       Completed without error       00%      6514         -
#14  Short offline       Completed without error       00%      6346         -
#15  Short offline       Completed without error       00%      6178         -
#16  Short offline       Completed without error       00%      6130         -
#17  Short offline       Completed without error       00%      5962         -
#18  Short offline       Completed without error       00%      5794         -
#19  Short offline       Completed without error       00%      5626         -
#20  Short offline       Completed without error       00%      5458         -
#21  Short offline       Completed without error       00%      5386         -
/# smartctl -a /dev/ada5
ATA Version is:   8
Local Time is:    Fri Nov 23 18:13:35 2012 EST
					was never started.
					been run.
data collection: 		(20160) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 336) minutes.
  2 Throughput_Performance  0x0026   056   056   000    Old_age   Always       -       18324
  3 Spin_Up_Time            0x0023   067   044   025    Pre-fail  Always       -       10155
  4 Start_Stop_Count        0x0032   094   094   000    Old_age   Always       -       6765
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       10665
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       103
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       363
191 G-Sense_Error_Rate      0x0022   096   096   000    Old_age   Always       -       47818
194 Temperature_Celsius     0x0002   064   064   000    Old_age   Always       -       26 (Min/Max 18/32)
199 UDMA_CRC_Error_Count    0x0036   100   100   000    Old_age   Always       -       13
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       1164
225 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       6774
No Errors Logged
# 1  Extended offline    Completed without error       00%     10661         -
# 2  Short offline       Completed without error       00%     10615         -
# 3  Short offline       Completed without error       00%      7653         -
# 4  Short offline       Completed without error       00%      7485         -
# 5  Short offline       Completed without error       00%      7317         -
# 6  Short offline       Completed without error       00%      7269         -
# 7  Short offline       Completed without error       00%      7117         -
# 8  Short offline       Completed without error       00%      6949         -
# 9  Short offline       Completed without error       00%      6781         -
#10  Short offline       Completed without error       00%      6613         -
#11  Short offline       Completed without error       00%      6541         -
#12  Short offline       Completed without error       00%      6373         -
#13  Short offline       Completed without error       00%      6205         -
#14  Short offline       Completed without error       00%      6037         -
#15  Short offline       Completed without error       00%      5869         -
#16  Short offline       Completed without error       00%      5821         -
#17  Short offline       Completed without error       00%      5653         -
#18  Short offline       Completed without error       00%      5485         -
#19  Short offline       Completed without error       00%      5317         -
#20  Short offline       Completed without error       00%      5149         -
#21  Short offline       Completed without error       00%      5077         -
