So, I got the dreaded SMART error email today. I've got 15 current_pending_sector and offline_unreadable errors. I've been following this procedure to scan and try to fix it; so far it doesn't seem to be working.
Any tips would be appreciated. Here's my most recent output from smartctl -a.
The errors toward the end seem to have occurred while I was trying to scan and fix.
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1CH166
Serial Number: <redacted>
LU WWN Device Id: 5 000c50 04e2acf1e
Firmware Version: CC43
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Feb 22 17:26:04 2014 CST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 584) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 338) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 111 099 006 Pre-fail Always - 215395677
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 40
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 8
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 20338659
9 Power_On_Hours 0x0032 087 087 000 Old_age Always - 11770
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 40
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 094 094 000 Old_age Always - 6
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 065 057 045 Old_age Always - 35 (Min/Max 28/43)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 2878
194 Temperature_Celsius 0x0022 035 043 000 Old_age Always - 35 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 15
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 15
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2983h+11m+29.436s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 20530174758
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 20851656301
SMART Error Log Version: 1
ATA Error Count: 5
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 11768 hours (490 days + 8 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 01 ff ff ff 4f 00 1d+12:52:04.880 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 1d+12:52:04.854 READ LOG EXT
60 00 01 ff ff ff 4f 00 1d+12:52:01.992 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 1d+12:52:01.937 READ LOG EXT
60 00 01 ff ff ff 4f 00 1d+12:51:59.079 READ FPDMA QUEUED
Error 4 occurred at disk power-on lifetime: 11768 hours (490 days + 8 hours)
2f 00 01 10 00 00 00 00 1d+12:51:59.053 READ LOG EXT
60 00 01 ff ff ff 4f 00 1d+12:51:56.199 READ FPDMA QUEUED
Error 3 occurred at disk power-on lifetime: 11768 hours (490 days + 8 hours)
2f 00 01 10 00 00 00 00 1d+12:51:56.119 READ LOG EXT
60 00 01 ff ff ff 4f 00 1d+12:51:52.953 READ FPDMA QUEUED
Error 2 occurred at disk power-on lifetime: 11768 hours (490 days + 8 hours)
b0 d1 01 01 4f c2 40 00 1d+12:36:39.000 SMART READ ATTRIBUTE THRESHOLDS [OBS-4]
b0 d0 01 00 4f c2 40 00 1d+12:36:38.931 SMART READ DATA
Error 1 occurred at disk power-on lifetime: 11768 hours (490 days + 8 hours)
ec 00 01 00 00 00 40 00 1d+12:36:38.929 IDENTIFY DEVICE
b0 d5 01 01 4f c2 40 00 1d+12:31:44.262 SMART READ LOG
# 1 Extended offline Completed: read failure 90% 11769 4142374576
# 2 Extended offline Completed: read failure 30% 11765 4142374576
# 3 Extended offline Aborted by host 90% 11759 -
# 4 Short offline Completed without error 00% 6766 -
# 5 Short offline Completed without error 00% 6765 -
# 6 Short offline Completed without error 00% 6764 -
# 7 Short offline Completed without error 00% 6763 -
# 8 Short offline Completed without error 00% 6762 -
# 9 Short offline Completed without error 00% 6761 -
#10 Short offline Completed without error 00% 6760 -
#11 Short offline Completed without error 00% 6759 -
#12 Short offline Completed without error 00% 6758 -
#13 Short offline Completed without error 00% 6757 -
#14 Short offline Completed without error 00% 6756 -
#15 Short offline Completed without error 00% 6756 -
#16 Short offline Completed without error 00% 6754 -
#17 Short offline Completed without error 00% 6753 -
#18 Short offline Completed without error 00% 6752 -
#19 Short offline Completed without error 00% 6751 -
#20 Short offline Completed without error 00% 6750 -
#21 Short offline Completed without error 00% 6749 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
