Steiner-SE
- Jul 13, 2020
Just checking and looking for thoughts.
I just build my TrueNAS machine and I'm in the progress of copying everything over between the two NAS system (the old one being a Xpenology NAS)
When done with the media folder (about 16TB) I marked all the subfolders in the media directory in both the old and new NAS and selected properties to check that everything had been copied (match file count and sizes).
The properties scan took several minutes longer on the TrueNAS machine than on the old Xpenology one.
There are some differences, but not sure what affects the most
Xpenology 1 disk redundancy 6*4TB using BTRFS
TrueNAS 1 disk redundancy 3*12TB using ZFS (duh)
Data is 27865 files in 3303 folders, 14.3TB
