Steiner-SE
- Jul 13, 2020
Not sure what subforum this should go in so I hope admins can move it to the most appropriate place.
I have a big mess on my hand now as I started settings up the NAS under the domain controller but now have decided to move away from it and just run my machines in a workgroup. If I remove the NAS from the domain I lose access to all shares, If I keep it on the domain both domain and non domain machines have some access to it.
I've probably made a big mess of permissions and ACLs during this. Folders and files created from a non domain machine is only workable from said machines and vice versa for domain machines. It seems I can not change owner or permissions from windows to remedy this either.
I have created a user and group on the nas and I can set the user as owner in filesystem permissions (from the nas), but can not set the group, it's stuck as "wheel".
What I really want to do here is:
A: Remove the NAS from domain but keep it fully accessible.
B: Remove all machines from domain and be in a workgroup instead, and retain access to NAS and each other.
C: Make all shares/files etc accessible and editable under above conditions.
I'm not quite sure in what end to start or exactly what needs to be done here since Windows won't allow me to add or change permissions/owner for any files and folders (Says I need permissions but doesn't allow me to give credentials for said permissions).
Machines on the VM/machine side are Windows 10 pro/enterprise, Server 2016 and Server 2019.
I'm setting up local users on all machines with the same name/pass as the account I set up on the NAS (think that is needed?) and make those administrators.
This is all a bit of a jungle to me and I fear I've made a big mess of it all after my move from Xpenology to TrueNAS Core (TrueNAS being a bit more involved than Synology).
