Slow Transfers After Upgrading to 9.1
derekvw
We were running an 8.x environment until this weekend. I upgraded to 9.1 and have seen painfully slow transfers ever since. I'm talking 500 KB/sec transfers. We were seeing around 30-50 MB/sec before the upgrade. This occurs on both SMB and AFP shares.
Are there any suggestions to improve speed? If you need any more information, let me know.
Thanks!
gpsguy
Active Member
Buy a new server or downgrade to the old version.:rolleyes:
It's like saying the car is slow, but you neglected to tell us it's got a flat tire or a blown headgasket.
Please provide relevant information in item 3 of the Forum Rules.
derekvw
Sorry about that. Here is more information...
FreeNAS 9.1 32 Bit
Intel Atom D2700
3300 MB Ram
Jetway JNF9D-2700
2x Realtek RTL8111EVL
Surprise.. you are using an underpowered CPU with FreeNAS.
derekvw
I never once reached high CPU utilization under 8.3. Is it really a huge increase in system resources to 9.1? We ran the system for over a year with fine performance up until the upgrade. If the upgrade really needs that much out of the processor, I'll just downgrade.
Going from FreeBSD 8 to FreeBSD 9 is like going from Windows XP to Vista. It's a pretty big jump, and if you are already underpowered it could put you off the cliff.
derekvw
Ok. I've downgraded back to 8.3. The same transfer that used 75-90% CPU utilization in 9.1 is only using 5-10% in 8.3.
cool. :) Guess you're stuck on 8.3.1 :(
J
jkh
Guest
Can you tell me which process? Is it only afpd and/or smbd? How much free memory does top show you in both incarnations of the system? I'm well acquainted with software bloat, but 5-10% going to 75-90% does seem a bit excessive, and you may have in fact encountered one or more bugs that only manifest themselves in low-resource scenarios. It would be good to know more. Thanks.
TenzoR
I have a similar problem I was wondering if anyone can help. Note: I did a fresh install and not an upgrade.
FreeNas 8.3.1 / 9.1.1
Intel S1200KPR
i3-3220
16GB ECC DDR3
2x2TB Mirror ZFS
Only one interface is being used
Autotune enabled
8.3.1 Speed
Transfer from NAS to PC = 80MB/s on average
Transfer from PC to NAS = 100MB/s on average
9.1.1 Speed
Transfer from NAS to PC = 25MB/s on average
I'm some what puzzled. For the upgrade, I exported my zpool then autoimport it once the new FreeNas was up. The other settings I re-did but nothing special just CIFS. Any suggestion?
