matthewrwright
 - Oct 23, 2015
Apologies in advance that my first forum post is a problem.
I have a Dell Powered 2950 running BIOS 2.5.0, 32Gb Ram, Dual Xeon CPU. 4x2Tb WD drives in Raid Z1, 1x 147Gb Seagate 15k SAS as Zil. 2x Broadcom Gigabit NIC in LACP port channel onto a Cisco 2960 switch. Boot environment is an 8Gb USB stick (I believe Kingston but it's in the internal USB socket on the motherboard so I'd have to de-rack the machine to check) Freenas version is 9.3.
Various plugins are installed - from memory these are:
Sabnzbd
Headphones
Couchpotato
Plex
Sonarr
Virtualbox - running 2x 2gb Linux VM's which were shut down at the time
BTSync
Having the day off work, I decided it was time to do some housekeeping and update my plugins while there was no one at home to complain that Plex had gone offline. Hit the upgrade for Plex plugin and went to make a coffee. Came back and it was still showing 50% updated - weird, it's usually done by now!
Left it running a further 20 minutes, then realised that I couldn't actually ping the Freenas Box.
I fired up the remote access card on the box and spotted that the box was showing an error related to being Out Of Swap Space and processes being killed. The box was hung, wouldn't respond to anything, so I hit the reset button.
Now out of swap space intrigues me as I have 32Gb of RAM and I believe the default is 2Gb swap space per disk, so all in all 40Gb of available "memory"
Having hit reset the machine has started booting and is now stuck with slow spa_sync
Last log lines I can see on the screen
I read on one of the forum posts that Ctrl+T could be pressed to get some status. I've done that, however I don't know what it means :P
My question really - what do I do next ? Is it a wait and see job, is it a reinstall Freenas on a new stick job?
I have my important data backed up by hourly rsync task to a Linux server elsewhere on the network, so it's not the absolute end of the world if it ends up being a rebuild, but I'd rather avoid the hassle if at all possible.
Any help appreciated
Matthew
Sabnzbd
Headphones
Couchpotato
Plex
Sonarr
BTSync
Beginning ZFS volume imports Importing 11152677867531535824 txg 5625957 open pool version 5000; software version 5000/5; uts 9.3-RELEASE-p2 txg 5625960 import pool version 5000; software version 5000/5; its 9.3-RELEASE- slow spa_sync: started 1320 seconds ago, calls 65
load: 0.57 cmd: zpool 778 [zio->io_cv] 2511.25r 0.00u 40.92s 0% 8480k
Matthew
