(Edited to add the system specifications and other needed data)
I've upgraded a FreeNAS from 9.2 to 9.3, and after rebooting it gets stuck at
The seconds count increases as time passes, and the calls count also does it.
if I press Ctrl+T I get something like:
The system has 6x3TB disks in RAIDZ2, and had 8GB RAM. After reading some on the forums, powered off the system, removed the RAM, and inserted 16GB. No luck.
If I use a new USB stick with a fresh FreeNAS 9.3 install, from the GUI I can start the volume import, but the step 2 takes forever and does not seem to end.
After starting the import, if I open a shell from putty or the physical console, a zpool status shows all normal: the state is ONLINE for the pool, the VDEV and all the disks. Also says "No known data errors"
From the shell, I can navigate to the tank, the datasets, the folders, and see the files.
I can enter the .zfs folder on the tank, but if I try to list the contents of the snapshot folder, the console gets stuck waiting for the command to finish.
And we just discovered we need the snapshots, cause something was lost at some point, but should be on the snapshots.
Any help on recovering this would be appreciated.
System:
Motherboard: Gigabyte GA-Z77M-D3H
NIC: Integrated on motherboard, Atheros chip AR8151 v2.0
RAM: 16GB, non-ECC
CPU: i7-3770 @ 3,4GHz
Disks: 6 x 3TB, plugged to the motherboard
At start the disks where Seagate, but as time passed I changed some of them to WD Red
* 2x Seagate 3TB SATA (ST3000DM001)
* 4x Western Digital NAS 3TB: WDC WD30EFRX
ZFS:
Filesystem version 5
ZFS storage pool version: feature support (5000)
The pool was vreated with 512b size, cause when I created it the GUI created it with that size. Since a given FreeNAS upgrade (don't remember wich on), I use the Ashift tunables needed to make it work.
Boot:
USB 8GB. Kingston data traveler 3.0
CLI:
I tried zpool Import and zpool Export
Now I do know is a mistake, after reading Cyberjock newbie guide, but what is done, is done.
Upgrade:
Standard from the GUI
Thanks again for your time and patience :)
Beginning ZFS volume imports Importing 152162520229915532 txg 10493740 open pool version 5000; software version 5000/5; uts 9.3-RELEASE-p txg 10493742 import pool version 5000; software version 5000/5; uts 9.3-RELEASE slow spa_sync: started 68789 seconds ago, calls 13560
load: 0.00 cmd: zfs 734 [] 68792.32r 0.00u 0.00s 0% 3008k
System:
RAM: 16GB, non-ECC
ZFS:
Boot:
CLI:
Upgrade:
