Slow SMB performance from SSD Striped pool
Tino Zidore
Member
Hi
I have been trying to tweak the Auxiliary parameters and System Tunables to perform best possible on SMB to Mac OS X and Windows 7/10
Please help me with my read speeds what parameter have I tweaked the wrong way?
I use a 10 G setup and I have almost full throughput using iperf.
I have add the no_signing parameter to the local Mac OS X nsmb.conf file and reboot, but no luck with the speeds.
With AJA system test I get a write 786 MB/s, which is okay, but my read is only at a max of 75 MB/s(see attached file).
I have also attached a image of my Tunables though the Web GUI.
Here is the setup at the moment.
System/Hardware
sysctl.conf
smb4.conf
System/Hardware:
Mobo:
Supermicro X10DRi-T (2 x onboard X540T)
RAM:
256 GB RAM 2133 Mhz
NICs:
1 x Intel XL710-QDA2
2 x Intel X520-SR2
1 x LSI 9207e8 - 69 spinning disks
1 x LSI 9300i8 - 10 SSD disks - Samsung 850 EVO 1 TB
Auxiliary parameters:
mangled names=no
store dos attributes = no
map archive = no
map hidden = no
map readonly = no
map system = no
read raw = yes
write raw = yes
ZFS Tunables:
ZFS Tunable (sysctl):
kern.maxusers 16711
vm.kmem_size 343413379072
vm.kmem_size_scale 1
vm.kmem_size_min 0
vm.kmem_size_max 1319413950874
vfs.zfs.vol.unmap_enabled 1
vfs.zfs.vol.mode 2
vfs.zfs.sync_pass_rewrite 2
vfs.zfs.sync_pass_dont_compress 5
vfs.zfs.sync_pass_deferred_free 2
vfs.zfs.zio.dva_throttle_enabled 1
vfs.zfs.zio.exclude_metadata 0
vfs.zfs.zio.use_uma 1
vfs.zfs.zil_slog_limit 786432
vfs.zfs.cache_flush_disable 0
vfs.zfs.zil_replay_disable 0
vfs.zfs.version.zpl 5
vfs.zfs.version.spa 5000
vfs.zfs.version.acl 1
vfs.zfs.version.ioctl 7
vfs.zfs.debug 0
vfs.zfs.super_owner 0
vfs.zfs.min_auto_ashift 12
vfs.zfs.max_auto_ashift 13
vfs.zfs.vdev.queue_depth_pct 1000
vfs.zfs.vdev.write_gap_limit 4096
vfs.zfs.vdev.read_gap_limit 32768
vfs.zfs.vdev.aggregation_limit 131072
vfs.zfs.vdev.trim_max_active 64
vfs.zfs.vdev.trim_min_active 1
vfs.zfs.vdev.scrub_max_active 2
vfs.zfs.vdev.scrub_min_active 1
vfs.zfs.vdev.async_write_max_active 10
vfs.zfs.vdev.async_write_min_active 1
vfs.zfs.vdev.async_read_max_active 3
vfs.zfs.vdev.async_read_min_active 1
vfs.zfs.vdev.sync_write_max_active 10
vfs.zfs.vdev.sync_write_min_active 10
vfs.zfs.vdev.sync_read_max_active 10
vfs.zfs.vdev.sync_read_min_active 10
vfs.zfs.vdev.max_active 1000
vfs.zfs.vdev.async_write_active_max_dirty_percent60
vfs.zfs.vdev.async_write_active_min_dirty_percent30
vfs.zfs.vdev.mirror.non_rotating_seek_inc1
vfs.zfs.vdev.mirror.non_rotating_inc 0
vfs.zfs.vdev.mirror.rotating_seek_offset1048576
vfs.zfs.vdev.mirror.rotating_seek_inc 5
vfs.zfs.vdev.mirror.rotating_inc 0
vfs.zfs.vdev.trim_on_init 1
vfs.zfs.vdev.larger_ashift_minimal 0
vfs.zfs.vdev.bio_delete_disable 0
vfs.zfs.vdev.bio_flush_disable 0
vfs.zfs.vdev.cache.bshift 16
vfs.zfs.vdev.cache.size 0
vfs.zfs.vdev.cache.max 16384
vfs.zfs.vdev.metaslabs_per_vdev 200
vfs.zfs.vdev.trim_max_pending 10000
vfs.zfs.txg.timeout 5
vfs.zfs.trim.enabled 1
vfs.zfs.trim.max_interval 1
vfs.zfs.trim.timeout 30
vfs.zfs.trim.txg_delay 32
vfs.zfs.space_map_blksz 4096
vfs.zfs.spa_min_slop 134217728
vfs.zfs.spa_slop_shift 5
vfs.zfs.spa_asize_inflation 24
vfs.zfs.deadman_enabled 1
vfs.zfs.deadman_checktime_ms 5000
vfs.zfs.deadman_synctime_ms 1000000
vfs.zfs.debug_flags 0
vfs.zfs.recover 0
vfs.zfs.spa_load_verify_data 1
vfs.zfs.spa_load_verify_metadata 1
vfs.zfs.spa_load_verify_maxinflight 10000
vfs.zfs.ccw_retry_interval 300
vfs.zfs.check_hostid 1
vfs.zfs.mg_fragmentation_threshold 85
vfs.zfs.mg_noalloc_threshold 0
vfs.zfs.condense_pct 200
vfs.zfs.metaslab.bias_enabled 1
vfs.zfs.metaslab.lba_weighting_enabled 1
vfs.zfs.metaslab.fragmentation_factor_enabled1
vfs.zfs.metaslab.preload_enabled 1
vfs.zfs.metaslab.preload_limit 3
vfs.zfs.metaslab.unload_delay 8
vfs.zfs.metaslab.load_pct 50
vfs.zfs.metaslab.min_alloc_size 33554432
vfs.zfs.metaslab.df_free_pct 4
vfs.zfs.metaslab.df_alloc_threshold 131072
vfs.zfs.metaslab.debug_unload 0
vfs.zfs.metaslab.debug_load 0
vfs.zfs.metaslab.fragmentation_threshold70
vfs.zfs.metaslab.gang_bang 16777217
vfs.zfs.free_bpobj_enabled 1
vfs.zfs.free_max_blocks 18446744073709551615
vfs.zfs.no_scrub_prefetch 0
vfs.zfs.no_scrub_io 0
vfs.zfs.resilver_min_time_ms 3000
vfs.zfs.free_min_time_ms 1000
vfs.zfs.scan_min_time_ms 1000
vfs.zfs.scan_idle 50
vfs.zfs.scrub_delay 4
vfs.zfs.resilver_delay 2
vfs.zfs.top_maxinflight 32
vfs.zfs.delay_scale 500000
vfs.zfs.delay_min_dirty_percent 60
vfs.zfs.dirty_data_sync 67108864
vfs.zfs.dirty_data_max_percent 10
vfs.zfs.dirty_data_max_max 4294967296
vfs.zfs.dirty_data_max 4294967296
vfs.zfs.max_recordsize 1048576
vfs.zfs.zfetch.array_rd_sz 1048576
vfs.zfs.zfetch.max_distance 33554432
vfs.zfs.zfetch.min_sec_reap 2
vfs.zfs.zfetch.max_streams 8
vfs.zfs.prefetch_disable 0
vfs.zfs.send_holes_without_birth_time 1
vfs.zfs.mdcomp_disable 0
vfs.zfs.nopwrite_enabled 1
vfs.zfs.dedup.prefetch 1
vfs.zfs.l2c_only_size 0
vfs.zfs.mfu_ghost_data_esize 215978792448
vfs.zfs.mfu_ghost_metadata_esize 0
vfs.zfs.mfu_ghost_size 215978792448
vfs.zfs.mfu_data_esize 20093289472
vfs.zfs.mfu_metadata_esize 1356146176
vfs.zfs.mfu_size 21672891904
vfs.zfs.mru_ghost_data_esize 25354312192
vfs.zfs.mru_ghost_metadata_esize 0
vfs.zfs.mru_ghost_size 25354312192
vfs.zfs.mru_data_esize 212660954112
vfs.zfs.mru_metadata_esize 844736512
vfs.zfs.mru_size 215989390336
vfs.zfs.anon_data_esize 0
vfs.zfs.anon_metadata_esize 0
vfs.zfs.anon_size 9412608
vfs.zfs.l2arc_norw 0
vfs.zfs.l2arc_feed_again 1
vfs.zfs.l2arc_noprefetch 0
vfs.zfs.l2arc_feed_min_ms 200
vfs.zfs.l2arc_feed_secs 1
vfs.zfs.l2arc_headroom 2
vfs.zfs.l2arc_write_boost 40000000
vfs.zfs.l2arc_write_max 10000000
vfs.zfs.arc_meta_limit 61814407680
vfs.zfs.arc_free_target 453079
vfs.zfs.compressed_arc_enabled 1
vfs.zfs.arc_shrink_shift 7
vfs.zfs.arc_average_blocksize 8192
vfs.zfs.arc_min 33325678592
vfs.zfs.arc_max 247257630720
sysctl.conf:
kern.metadelay=3
kern.dirdelay=4
kern.filedelay=5
kern.coredump=1
kern.sugid_coredump=1
net.inet.tcp.delayed_ack=0
vfs.timestamp_precision=3
net.link.lagg.lacp.default_strict_mode=0
# Force minimal 4KB ashift for new top level ZFS VDEVs.
vfs.zfs.min_auto_ashift=12
smb4.conf:
[global]
server max protocol = SMB3_11
interfaces = 127.0.0.1 xx.xx.xx.xx
bind interfaces only = yes
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 7545674
logging = file
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
directory name cache size = 0
kernel change notify = no
server string = RAW Server
ea support = yes
store dos attributes = yes
lm announce = yes
acl allow execute always = true
dos filemode = yes
multicast dns register = yes
domain logons = no
idmap config *: backend = tdb
server role = member server
workgroup = WORKGROUP
realm = MY Domain.com
security = ADS
client use spnego = yes
cache directory = /var/tmp/.cache/.samba
local master = no
domain master = no
preferred master = no
ads dns update = yes
winbind cache time = 7200
winbind offline logon = yes
winbind enum users = yes
winbind enum groups = yes
winbind nested groups = yes
winbind use default domain = no
winbind refresh tickets = yes
idmap config WORKGROUP: backend = rid
idmap config WORKGROUP: range = 20000-90000000
allow trusted domains = no
client ldap sasl wrapping = sign
template shell = /bin/sh
template homedir = /home/%D/%U
netbios name = RAW
pid directory = /var/run/samba
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP850
unix charset = UTF-8
log level = 2
mangled names=no
map archive = no
map hidden = no
map readonly = no
map system = no
read raw = yes
write raw = yes
[SSDTEST]
path = /mnt/SSDTANK/SSDTEST
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
vfs objects = zfs_space zfsacl catia fruit streams_xattr aio_pthread
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
m0nkey_
Dedicated Sage
Ack! Turn off all that autotune crap. Remove all the autotune tuneables and reboot. Then re-test the performance.
