Arch Willingham
- Feb 21, 2017
I have a FreeNAS 11 server set up to share a RAID1 array. For the most part, I use it to have various Windows virtual machines run a backup with the FreeNAS box as the SMB target and they also backup to local drives on a local datastore on the esxi server. It works great and all is well.
A few days ago, I had to kill local drive in the esxi server so I moved the two local datastores to an NFS share on the FreeNAS box and re-added the datastore to the two virtual machines. Those two machines still do their windows backups: one to a "local" drive (which is actually now a datastore on the NFS share and one to a SMB network share on the FreeNAS box.
The weird part is they are vastly different in speed even though they are both traveling over the same network, to the same FreeNAS box using the same FreeNAS drives.
In each case, NFS is almost double what SMB is. Is that normal?
Arch
System info:
Hostname freenas
Build FreeNAS-11-MASTER-201707070510 (b563983)
Platform Intel(R) Xeon(R) CPU E31240 @ 3.30GHz
Memory 16346MB
Pool info:
Output from
Computer Minutes Data -GB GB/Minute Share VM1 104 334.78 54.93825641 "local drive" on NFS datastore VM1 278 331.96 20.37931894 SAMBA netwrk share VM2 192 696.67 61.92622222 "local drive" on NFS datastore VM2 432 696.65 27.52197531 SAMBA netwrk share
Arch
System info:
Hostname freenas
Memory 16346MB
Pool info:
pool: vol0001 state: ONLINE scan: scrub repaired 0 in 7h32m with 0 errors on Sun Jun 4 07:33:01 2017 config: NAME STATE READ WRITE CKSUM vol0001 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/7db60122-0b56-11e7-b406-000c29b5a6d4 ONLINE 0 0 0 gptid/7ec8a881-0b56-11e7-b406-000c29b5a6d4 ONLINE 0 0 0
Output from
testparm -vvv
# Global parameters [global] bind interfaces only = No config backend = file dos charset = CP437 enable core files = Yes interfaces = multicast dns register = Yes netbios aliases = netbios name = FREENAS netbios scope = realm = server services = s3fs, rpc, nbt, wrepl, ldap, cldap, kdc, drepl, winbindd, ntp_signd, kcc, dnsupdate, dns server string = FreeNAS Server share backend = classic unix charset = UTF-8 workgroup = FREENASWRKGRP browse list = Yes domain master = Auto enhanced browsing = Yes lm announce = Yes lm interval = 60 local master = Yes os level = 20 preferred master = Auto ads dns update = Yes allow dns updates = secure only dns forwarder = dns update command = /usr/local/sbin/samba_dnsupdate machine password timeout = 604800 nsupdate command = /usr/local/bin/samba-nsupdate -g rndc command = /usr/sbin/rndc spn update command = /usr/local/sbin/samba_spnupdate mangle prefix = 1 mangling method = hash2 max stat cache size = 256 stat cache = Yes client ldap sasl wrapping = sign ldap admin dn = ldap connection timeout = 2 ldap delete dn = No ldap deref = auto ldap follow referral = Auto ldap group suffix = ldap idmap suffix = ldap machine suffix = ldap page size = 1000 ldap passwd sync = no ldap replication sleep = 1000 ldap server require strong auth = Yes ldap ssl = start tls ldap ssl ads = No ldap suffix = ldap timeout = 15 ldap user suffix = lock spin time = 200 oplock break wait time = 0 smb2 leases = Yes debug class = No debug hires timestamp = Yes debug pid = No debug prefix timestamp = No debug uid = No ldap debug level = 0 ldap debug threshold = 10 log file = logging = file log level = 2 max log size = 51200 syslog = 1 syslog only = No timestamp logs = Yes abort shutdown script = add group script = add machine script = add user script = add user to group script = allow nt4 crypto = No delete group script = delete user from group script = delete user script = domain logons = No enable privileges = Yes init logon delay = 100 init logon delayed hosts = logon drive = logon home = \\%N\%U logon path = \\%N\%U\profile logon script = reject md5 clients = No set primary group script = shutdown script = add share command = afs token lifetime = 604800 afs username map = allow insecure wide links = No async smb echo handler = No auto services = cache directory = /var/db/samba4 change notify = Yes change share command = cluster addresses = clustering = No config file = ctdbd socket = ctdb locktime warn threshold = 0 ctdb timeout = 0 default service = delete share command = homedir map = auto.home kernel change notify = No lock directory = /var/lock log writeable files on exit = No message command = nbt client socket address = 0.0.0.0 ncalrpc dir = /var/run/samba4/ncalrpc NIS homedir = No nmbd bind explicit broadcast = Yes panic action = /usr/local/libexec/samba/samba-backtrace perfcount module = pid directory = /var/run/samba registry shares = No remote announce = remote browse sync = reset on zero vc = No smbd profiling level = off state directory = /var/db/samba4 usershare allow guests = No usershare max shares = 0 usershare owner only = Yes usershare path = /var/db/samba4/usershares usershare prefix allow list = usershare prefix deny list = usershare template share = utmp = No utmp directory = wtmp directory = addport command = addprinter command = cups connection timeout = 30 cups encrypt = No cups server = deleteprinter command = disable spoolss = Yes enumports command = iprint server = load printers = No lpq cache time = 30 os2 driver map = printcap cache time = 750 printcap name = /dev/null show add printer wizard = Yes cldap port = 389 client ipc max protocol = default client ipc min protocol = default client max protocol = default client min protocol = CORE client use spnego = Yes dcerpc endpoint servers = epmapper, wkssvc, rpcecho, samr, netlogon, lsarpc, drsuapi, dssetup, unixinfo, browser, eventlog6, backupkey, dnsserver defer sharing violations = Yes dgram port = 138 disable netbios = No enable asu support = No eventlog list = large readwrite = Yes lsa over netlogon = No max mux = 50 max ttl = 259200 max wins ttl = 518400 max xmit = 16644 min receivefile size = 0 min wins ttl = 21600 name resolve order = lmhosts wins host bcast nbt port = 137 nt pipe support = Yes nt status support = Yes read raw = Yes rpc big endian = No rpc server port = 0 server max protocol = SMB3 server min protocol = LANMAN1 server multi channel support = No smb2 max credits = 8192 smb2 max read = 8388608 smb2 max trans = 8388608 smb2 max write = 8388608 smb ports = 445 139 svcctl list = time server = Yes unicode = Yes unix extensions = Yes use spnego = Yes web port = 901 write raw = Yes algorithmic rid base = 1000 allow dcerpc auth level connect = No allow trusted domains = Yes auth methods = check password script = client ipc signing = default client lanman auth = No client NTLMv2 auth = Yes client plaintext auth = No client schannel = Auto client signing = default client use spnego principal = No dedicated keytab file = encrypt passwords = Yes guest account = nobody kerberos encryption types = all kerberos method = default kpasswd port = 464 krb5 port = 88 lanman auth = No log nt token command = map to guest = Bad User map untrusted to domain = No ntlm auth = Yes ntp signd socket directory = /var/run/samba4/ntp_signd null passwords = No obey pam restrictions = Yes old password allowed period = 60 pam password change = No passdb backend = tdbsam passdb expand explicit = No passwd chat = *new*password* %n\n *new*password* %n\n *changed* passwd chat debug = No passwd chat timeout = 2 passwd program = password hash gpg key ids = password server = * preload modules = private dir = /var/db/samba4/private raw NTLMv2 auth = No rename user script = restrict anonymous = 0 root directory = samba kcc command = /usr/local/sbin/samba_kcc security = USER server role = standalone server server schannel = Auto server signing = default smb passwd file = /var/db/samba4/private/smbpasswd tls cafile = tls/ca.pem tls certfile = tls/cert.pem tls crlfile = tls dh params file = tls enabled = Yes tls keyfile = tls/key.pem tls priority = NORMAL:-VERS-SSL3.0 tls verify peer = as_strict_as_possible unix password sync = No username level = 0 username map = username map cache time = 0 username map script = aio max threads = 100 deadtime = 15 getwd cache = Yes hostname lookups = Yes keepalive = 300 max disk size = 0 max open files = 470738 max smbd processes = 0 name cache timeout = 660 socket options = TCP_NODELAY use mmap = Yes get quota command = host msdfs = Yes set quota command = create krb5 conf = Yes idmap backend = tdb idmap cache time = 604800 idmap gid = idmap negative cache time = 120 idmap uid = include system krb5 conf = Yes neutralize nt4 emulation = No reject md5 servers = No require strong key = Yes template homedir = /home/%D/%U template shell = /bin/false winbind cache time = 300 winbindd privileged socket directory = /var/run/samba4/winbindd_privileged winbindd socket directory = /var/run/samba4/winbindd winbind enum groups = No winbind enum users = No winbind expand groups = 0 winbind max clients = 200 winbind max domain connections = 1 winbind nested groups = Yes winbind normalize names = No winbind nss info = template winbind offline logon = No winbind reconnect delay = 30 winbind refresh tickets = No winbind request timeout = 60 winbind rpc only = No winbind sealed pipes = Yes winbind separator = \ winbind trusted domains only = No winbind use default domain = No dns proxy = No wins hook = wins proxy = No wins server = wins support = No idmap config *: range = 90000001-100000000 idmap config * : backend = tdb comment = path = administrative share = No browseable = Yes case sensitive = Auto default case = lower delete veto files = No hide dot files = Yes hide files = hide special files = No hide unreadable = No hide unwriteable files = No mangled names = Yes mangling char = ~ map archive = Yes map hidden = No map readonly = yes map system = No preserve case = Yes short preserve case = Yes store dos attributes = Yes veto files = veto oplock files = blocking locks = Yes csc policy = manual fake oplocks = No kernel oplocks = No kernel share modes = Yes level2 oplocks = Yes locking = Yes oplock contention limit = 2 oplocks = Yes posix locking = Yes strict locking = No afs share = No available = Yes copy = delete readonly = No dfree cache time = 0 dfree command = directory name cache size = 0 dmapi support = No dont descend = dos filemode = Yes dos filetime resolution = No dos filetimes = Yes fake directory create times = No follow symlinks = Yes fstype = NTFS include = magic output = magic script = postexec = preexec = preexec close = No root postexec = root preexec = root preexec close = No spotlight = No volume = wide links = No cups options = default devmode = Yes force printername = No lppause command = lpq command = lpq -P'%p' lpresume command = lprm command = lprm -P'%p' %j max print jobs = 1000 max reported print jobs = 0 printable = No print command = lpr -r -P'%p' %s printer name = printing = bsd printjob username = %U print notify backchannel = No queuepause command = queueresume command = use client driver = No acl allow execute always = Yes acl check permissions = Yes acl map full control = Yes durable handles = Yes ea support = Yes map acl inherit = No nt acl support = Yes profile acls = No access based share enum = No acl group control = No admin users = create mask = 0666 directory mask = 0777 force create mode = 0000 force directory mode = 0000 force group = force unknown acl user = No force user = guest ok = No guest only = No hosts allow = hosts deny = inherit acls = No inherit owner = no inherit permissions = No invalid users = read list = read only = Yes smb encrypt = default valid users = write list = aio read size = 0 aio write behind = aio write size = 0 allocation roundup size = 1048576 block size = 1024 max connections = 0 min print space = 0 strict allocate = No strict rename = No strict sync = No sync always = No use sendfile = No write cache size = 0 msdfs proxy = msdfs root = No msdfs shuffle referrals = No ntvfs handler = unixuid, default vfs objects = [smbdata] path = "/mnt/vol0001/smbdata" veto files = /.snapshot/.windows/.mac/.zfs/ read only = No vfs objects = zfs_space zfsacl streams_xattr aio_pthread zfsacl:acesort = dontcare nfs4:chown = true nfs4:acedup = merge nfs4:mode = special
