SOLVED Size of pool
hugovsky
Maybe it's something I am not understanding but, where are my missing 4GiB ?
Where do you see 4GB missing?
4.0TB - 1.4GB = 2.6TB, which is exatly what that shows. 4GB is a rounding error when talking about TB of storage, so you can't even tell us that 4GB is missing from that screenshot.
Ok, but you aren't looking at the numbers properly. Notice that the first line says the pool is using 1.4TB.
depasseg
FreeNAS Replicant
You didn't show the entire pool table. So it sounds like you are looking at the explanation for the 1st level Tank showing 1.4TiB and the second level Tank showing 966GiB. Is there another dataset that you didn't provide an image of?
If not, then my guess is snapshots.
