Since V13.0-U3 noticed IPMI messages
profwalken
Well, I use an Asrockrack C2550D4I MB and I got in past years (2018) same kind of messages with IPMI.
Bios and BMC are up to date in latest release , bios 2.50 and BMC 00.35.00
I have no problems to use IPMI from a PC browser now even with those messages. (screenshot taken from ipmi session)
Tried to re read all posts I found on same problem, added a Tunable task to unload ipmi
is there something new in BMC management in TN13-U3 ?
dasti
Just updated to 13 and I also hae problem with ipmi with a asrock rack c2750, still at the beginning of investigations
CRITICAL​
Failed to check for alert IPMISELSpaceLeft: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/alert.py", line 740, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.9/site-packages/middlewared/alert/source/ipmi_sel.py", line 215, in check return self._produce_alert_for_ipmitool_output(await ipmitool(["sel", "info"])) File "/usr/local/lib/python3.9/site-packages/middlewared/alert/source/ipmi_sel.py", line 34, in __call__ raise CallError(f"ipmitool failed (code={result.returncode}): {result.stderr}") middlewared.service_exception.CallError: [EFAULT] ipmitool failed (code=1): No data available Get Device ID command failed Error receiving message: Input/output error No data available No valid response received Error receiving message: Input/output error Get SEL Info command failed​
profwalken
