I realize this is hardware related, but I was wondering if any of you run a similar setup as mine.
Case: Silverstone DS380
HDD: 4x HGST 6TB NAS drives (2 more on the way.)
Drives will be in the lower 6 slots of the 8 bay array. They will be a RaidZ2 array when the 2 extra drives arrive. I plan on putting a 7th 6TB drive in there that will be on it's own, for file swapping and putting none precious data there.
The problem I'm having is hard drive temperatures.
All the fans are spinning, the ones blowing on the hard drives seem to be doing well.
However, within 10-15 minutes of booting, my hard drives are in the high 40C to low 50C range, and that's without a load.
CPU on the other hand is sitting at 32C
Issue is, the way the case is designed, i don't think I can get more fans in there to cool the drives...
I'd welcome any advice.
Thanks,
-Phil
Thanks,
-Phil
