TheDubiousDubber
- Sep 11, 2014
Sickrage is refusing to download episodes as they become available. If I manually initiate the search it will fetch the show, pass to SABnzbd for download, and then post-process the show properly.
So everything works, but it is failing to find available shows on its own. It's the latest plugin on the latest release of FreeNAS. EP Status is also set to Wanted.
See log below:
It ran its own search and found nothing, and less than a minute later I ran a manual search and it fetched the episode.
You have to jump through hoops to get something posted on the sickrage forum, so hoping someone here can help.
See log below:
2016-02-05 17:56:01 INFO SEARCHQUEUE-MANUAL-295684 :: [NZBs.org] :: Found result Second.Chance.2016.S01E04.720p.HDTV.x264-AVS at https://nzbs.org/getnzb/longstringhere***** 2016-02-05 17:56:01 INFO SEARCHQUEUE-MANUAL-295684 :: [NZBs.org] :: Performing episode search for Second Chance (2016) 2016-02-05 17:56:01 INFO SEARCHQUEUE-MANUAL-295684 :: Beginning manual search for: [Second Chance (2016) - S01E04 - Admissions] 2016-02-05 17:55:47 INFO SEARCHQUEUE-DAILY-SEARCH :: No needed episodes found 2016-02-05 17:55:46 INFO SEARCHQUEUE-DAILY-SEARCH :: Beginning daily search for new episodes 2016-02-05 17:55:44 INFO DAILYSEARCHER :: No new released episodes found ... 2016-02-05 17:55:44 INFO DAILYSEARCHER :: Searching for new released episodes ... 2016-02-05 17:53:47 INFO POSTPROCESSER :: Successfully processed 2016-02-05 17:53:47 INFO POSTPROCESSER :: PostProcessing Path: /mnt/Downloads/TV Shows 2016-02-05 17:44:58 INFO SEARCHQUEUE-DAILY-SEARCH :: No needed episodes found 2016-02-05 17:44:45 INFO SEARCHQUEUE-DAILY-SEARCH :: Beginning daily search for new episodes 2016-02-05 17:44:43 INFO DAILYSEARCHER :: No new released episodes found ...
