SickRage _ Wont open "Add Shows"
Jeff Lamer
Hey All,
Fresh Install of BRANCH: (master) / COMMIT: (dbf446a51f8b6e900aba41e947ef9f925ae12714)
It wont allow me to open ADD Shows, It just kicks me back to the main screen. I see it has been posted on SR forum but did not see a resolve. Will try IRC channel and post here if unanswered.
cormad
Joshua Parker Ruehlig
Hey All,
cormad
there was discussed somewhere on this forum. I think the solution was clearing the 'mako cache' somehow.if you do post on the forum, do realize we're on the recently defected SickRage/SickRage repo, not the old SickRageTV/SickRage repo.
Jeff Lamer
Thats a bit confusing :)
This worked
The url layout was changed.
Go to http://yourip:port/config/ and make a note of the "SR Config Dir"
Stop SR, go to that directory, and delete the mako folder. While you are there may as well delete sessions, indexers, and rss if it is there.
Start SR.
This worked
Start SR.
Well you found the mako folder so I guess my directions were somewhat helpful =P
