Shutdown and reboot
HI,
I am new at Freenas. I have a new, up to date, stable, server (11.2 stable).
My problem is simple. When I do a "shutdown -h now", it hangs (minumum 10 minutes, then, I rebooted), I tried several times with same effect.
From the console, the last thing I see is:
GEOM_MIRROR: device swap0 destroyed.
But reboot seems to work without issue.
At boot, I don't see errors (at least, when I look at the screen, all looks good).
Does anyone have an idea of what could be wrong?
I am not a debian expert, so, if you need any more data to help, please tell me what command and/or what file you are interrested to.
Thank you for your help.
Christian
Redcoat
Patrick M. Hausen
To power off cleanly use shutdown -p now.
Patrick
Hi Patrick,
thank you, it works. I just wonder now, why on my centos systems, shutdown -h seems to do this correctly (in fact, it's the first time I read about -p...).
Anyway, it works.
Thank again to all developpers and to this forum gurus.
Christian
Patrick M. Hausen
FreeBSD simply differentiates. -h is halt, -p is power off. Sparc systems do the same. init 0 to halt, init 5 is power off.
Patrick
