So, I'm new to BSD (Linux user), but so far I think FreeNAS is the best solution for, well, my NAS. However, it seems the installer has created 2GB swap partitions on all my disks, including my 16GB SSD that I'm using for l2arc. This seems wasteful to me (10GB of swap total?), so I'm trying to get rid of it and grow the l2arc appropriately. However, I apparently don't understand the package manager.
Instead of trying to explain, I'll just show you what I'm seeing.
So, why can't I use (or remove) my supposedly installed software?
More importantly, perhaps, am I going down the right path with this swap thing at all? My /etc/fstab is below. ada0 is the one I want to remove, though I'd love to be able to resize the rest.
Thanks in advance for whatever help you can offer.
Edit: So, I ended up deleting the entire pool, recreating it, and adding the l2arc via the command line (so, swap free). The only thing now is that the cache disk doesn't show up in the GUI... and, of course, I'm still confused about the software installation.
/dev/gpt/swap-ada1 none swap sw 00 /dev/gpt/swap-ada2 none swap sw 00 /dev/gpt/swap-ada3 none swap sw 00 /dev/gpt/swap-ada4 none swap sw 00 /dev/gpt/swap-ada0 none swap sw 00
