I have a ZFS pool error.
What CLI can I run to correct my error?
Thanks
Starts with this error:
gpart:
zpool:
/etc/fstab:
Thanks
Aug 28 18:54:03 freenas kernel: ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present; Aug 28 18:54:03 freenas kernel: to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf. Aug 28 18:54:03 freenas kernel: ZFS filesystem version 4 Aug 28 18:54:03 freenas kernel: ZFS storage pool version 15 Aug 28 18:54:03 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad14. Aug 28 18:54:03 freenas kernel: ZFS WARNING: Unable to attach to ada4p1. Aug 28 18:54:03 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad16. Aug 28 18:54:03 freenas kernel: ZFS WARNING: Unable to attach to ada5p1. Aug 28 18:54:03 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd Aug 28 18:54:03 freenas root: /etc/rc: WARNING: failed to start smartd Aug 28 18:54:04 freenas ntpd[1307]: ntpd 4.2.4p5-a (1) Aug 28 18:54:04 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8 Aug 28 18:54:05 freenas kernel: em0: link state changed to UP Aug 28 18:54:13 freenas ntpd[1308]: time reset +0.440934 s Aug 28 19:01:08 freenas sshd[2184]: login_getclass: unknown class 'root' Aug 28 19:01:12 freenas sshd[2184]: login_getclass: unknown class 'root' Aug 28 19:09:28 freenas ntpd[1308]: kernel time sync status change 2001 Aug 28 20:48:37 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad14. Aug 28 20:48:37 freenas kernel: ZFS WARNING: Unable to attach to ada4p1. Aug 28 20:48:38 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad16. Aug 28 20:48:39 freenas kernel: ZFS WARNING: Unable to attach to ada5p1. Aug 28 20:49:25 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad14. Aug 28 20:49:25 freenas kernel: ZFS WARNING: Unable to attach to ada4p1. Aug 28 20:49:26 freenas kernel: ZFS WARNING: Unable to attach to gpt/swap-ad16. Aug 28 20:49:27 freenas kernel: ZFS WARNING: Unable to attach to ada5p1.
gpart:
freenas# gpart show => 63 7831467 da0 MBR (3.7G) 63 953505 1 freebsd [active] (466M) 953568 63 - free - (32K) 953631 953505 2 freebsd (466M) 1907136 3024 3 freebsd (1.5M) 1910160 41328 4 freebsd (20M) 1951488 5880042 - free - (2.8G) => 0 953505 da0s1 BSD (466M) 0 16 - free - (8.0K) 16 953489 1 !0 (466M) => 34 3907029101 ada4 GPT (1.8T) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 3902834703 2 freebsd-zfs (1.8T) => 34 3907029101 ada5 GPT (1.8T) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 3902834703 2 freebsd-zfs (1.8T) => 34 2930274987 mirror/RAID1Drive GPT (1.4T) 34 2930274987 1 freebsd-ufs (1.4T) => 63 390721842 mirror/RAIDiSCSI MBR (186G) 63 65 - free - (33K) 128 390716737 1 !251 (186G) 390716865 5040 - free - (2.5M)
zpool:
freenas# zpool status DiskPair1 pool: DiskPair1 state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://www.sun.com/msg/ZFS-8000-8A scrub: none requested config: NAME STATE READ WRITE CKSUM DiskPair1 ONLINE 0 0 0 mirror ONLINE 0 0 0 gpt/ad14 ONLINE 0 0 0 gpt/ad16 ONLINE 0 0 0
/etc/fstab:
freenas# cat /etc/fstab /dev/ufs/FreeNASs1a / ufs ro 1 1 /dev/ufs/FreeNASs3 /cfg ufs rw,noauto 2 2 /dev/ufs/FreeNASs4 /data ufs rw 2 2 /dev/gpt/swap-ad14 none swap sw 0 0 /dev/gpt/swap-ad16 none swap sw 0 0
