Daniel Winther Nielsen
- Jan 10, 2016
Hello guys, hopefully you can guide a complete noob a little so I can find if I should put the time into learning about FreeNAS or I should go with something easier.
I have been running a Windows Server 2012 server/media center PC in my living room. I had actually already decided to go with FreeNAS because the youtube videos make it sound nice and easy, but reading a little on here gave me the opposite impression.
I will only be using this for home use, no backup and no redundancy needed as it mainly going to be used as a media server for my living room and watching movies from my other computer (and maybe mobile devices). With PLEX or something similar installed.
So would FreeNAS be suitable for this, I already have 6 drives with data on them, if possible I dont want to format them, but they are using the NTFS filesystem. Is it possible to use the NTFS drives on freeNAS, as I said I dont want any raid drives just a bunch of drives.
Hopefully my noobish question is ok here :)
