Hey all - I spent quite a bit of time setting up my first FreeNAS and its now working beautifully. The system however is running off a lightly used Corsair X128 consumer grade SSD and it is the single point of failure. I am debating if I should change the SSD to an enterprise grade drive for long term reliability? Below is my current SMART Attribute for the OS drive:
[root@freenas] ~# smartctl -a /dev/ada7
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Device Model: Corsair CMFSSD-128D1
Serial Number: 3P51TNV7ZGX065S55F86
Firmware Version: 2.0
User Capacity: 128,035,676,160 bytes [128 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Fri Oct 23 17:25:58 2015 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x1d) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
Self-test supported.
No Selective Self-test supported.
power-saving mode.
Error logging capability: (0x00) Error logging NOT supported.
Short self-test routine
recommended polling time: ( 0) minutes.
Extended self-test routine
1 Raw_Read_Error_Rate 0x0000 006 000 000 Old_age Offline - 0
9 Power_On_Hours 0x0000 153 050 000 Old_age Offline - 0
12 Power_Cycle_Count 0x0000 215 000 000 Old_age Offline - 0
184 End-to-End_Error 0x0000 019 000 000 Old_age Offline - 0
195 Hardware_ECC_Recovered 0x0000 001 000 000 Old_age Offline - 0
196 Reallocated_Event_Count 0x0000 000 000 000 Old_age Offline - 0
197 Current_Pending_Sector 0x0000 000 000 000 Old_age Offline - 0
198 Offline_Uncorrectable 0x0000 159 103 000 Old_age Offline - 68016
199 UDMA_CRC_Error_Count 0x0000 115 145 000 Old_age Offline - 35406
200 Unknown_SSD_Attribute 0x0000 105 220 000 Old_age Offline - 951
201 Unknown_SSD_Attribute 0x0000 152 098 000 Old_age Offline - 504
202 Unknown_SSD_Attribute 0x0000 093 187 000 Old_age Offline - 42
203 Run_Out_Cancel 0x0000 007 053 000 Old_age Offline - 40
204 Soft_ECC_Correction 0x0000 000 000 000 Old_age Offline - 0
205 Thermal_Asperity_Rate 0x0000 016 039 000 Old_age Offline - 0
206 Unknown_SSD_Attribute 0x0000 001 000 000 Old_age Offline - 0
207 Unknown_SSD_Attribute 0x0000 069 071 000 Old_age Offline - 0
208 Unknown_SSD_Attribute 0x0000 066 002 000 Old_age Offline - 0
209 Unknown_SSD_Attribute 0x0000 095 000 000 Old_age Offline - 0
211 Unknown_Attribute 0x0000 000 000 000 Old_age Offline - 0
212 Unknown_Attribute 0x0000 000 000 000 Old_age Offline - 0
213 Unknown_Attribute 0x0000 000 000 000 Old_age Offline - 0
Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors Logged
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
