I am in the process of playing around with a test VM of 11.2-U3, with a view to upgrading/re-installing my home 9.2.1.6 server at some point in the near future.
One difference I have noticed while checking out shell access (through the GUI and SSH) is that when compared to 9, the 11 shell tab complete seems to be case sensitive where as under 9 it is not.
For example, if I have a folder called "Test", under 9.2.1.6 if I type "cd te" or "cd Te" and hit tab this completes to "cd Test", under 11.2-U3 it doesn't tab complete unless I type "cd Te" and hit tab.
Changing my user shell over to bash sorts it out for my user, however under root (either using the GUI shell or through SSH using su -) tab complete is still case sensitive. I am loathed to change the shell configured for root in case this has any knock on effects on the system (and having tested, it doesn't seem to make any difference anyway).
Obviously this is partly me being "lazy" or just taking advantage of an effort saving mechanism. Is this something that can be configured/changed (through either GUI or config files etc)? Or should I leave it alone for fear of breaking stuff?
I have had a search around but can't seem to find anything specific to FreeBSD/FreeNAS that seems to be relevant/works.
Thanks for any thoughts, or even suggestions as to why case insensitive tab complete is a bad thing, or why I shouldn't make such a change.
