Sharing a Folder
Scott VerLee
I'm new to FreeNAS. I have created a Volume with a dataset which I setup as a share. When I try to access the folder on a Windows server I get permission errors. It is a folder used for a back repository so I need this resolved quickly. Any ideas?
pirateghost
Unintelligible Geek
Have you looked at the documentation?
There are examples and explanations of the options.
If you're expecting us to know your setup, and give you a blanket "fix-it" solution, you won't find that here.
Scott VerLee
Version 9.10. Interface = iSCSI. Permissions: Owner (User) = root, Owner (Group). Permission Type: Windows. Compression ; lz4. Share Type: Windows - CIFS I try to create a folder on the shared folder and it tells me I need permission. Disks in Server Manager shows the disk as "Unknown",
pirateghost
Unintelligible Geek
I don't really understand what you're alluding to here.
You can't share iscsi out as a CIFS share.
