Scampicfx
- Jul 4, 2016
Hey guys,
I know this question was asked in the past a couple of times. Nevertheless, although reading all the other discussions, the shadow copies feature isn't working at my TrueNAS core system. I remember it was working loong ago in the past, but after an upgrade a few years ago, it stopped working. However, I need to get this fixed now.
- All my shares have the preset enabled "Default share paremeters", which means the shadow copies checkbox is checked
- All my shares are on dataset level
- I have configured a couple of period snapshot tasks with this naming schema: auto-%Y%m%d.%H%M-2w or auto-%Y%m%d.%H%M-2m or auto-%Y%m%d.%H%M-2y
- When looking at system -> Snapshots, I see nearly 10000 snapshots.
However, at my windows 11 computer, the shadow copies won't show up. I have the feeling that my computer isn't really looking up if there are any snapshots available (there is no progress circle spinning for example). It simply tells there are no snapshots. It feels like my computer doesn't even try to lookup if there are any snapshots.
What's the best way to investigate this problem? Do you have any recommendations?
