Setting up freenas as a print server
Ben Waywood
Hi all,
I have tried following this guide inside a jail shell printing-cups-configuring-server steps 1 and 2 completed without issues.
In step 3 I was unable to complete this optional section as the paths did not exist
In order to enable CUPS printing under certain Microsoft® Windows® clients, the line below should be uncommented in /usr/local/etc/cups/mime.types and /usr/local/etc/cups/mime.convs:
application/octet-stream
At the end of step 3 I can perform # /etc/rc.d/devfs restart in shell and I can perform # /usr/local/etc/rc.d/cupsd restart in the jail but the documentation seems to suggest that both should work from the jail, nevertheless I moved onto step 4 and was unable to access the UI.
I hope I have given enough information, please let me know if you need anything else. Thanks in advance for your help.
Bugstar
Hi Ben,
I'm going through some similar pain right now. Any chance you solved this issue AND remember how you managed it?
Cheers
