SOLVED setting static IP from gui
ives31
I want to set a static IP for my nasbox from the gui.
If I go to the NETWORK tab am I right in assuming that I then go to INTERFACES and then ADD INTERFACE?
If that's the case then I'm guessing:
1. ipv4 is the IP address I want the nas box to have
2.my netmask is my subnetmask
If I've got this right so far what do I fill in for ipv6?
Do I leave it blank?
thanks
thanks
If you're not using ipv6, leave that blank. Shouldn't be a problem.
